quent pye 16 #1 Posted February 16, 2023 (edited) I need a new hub for for my wheel the key way is stripped I also need a brake thing Edited February 17, 2023 by quent pye Photos 1 Share this post Link to post Share on other sites
Ed Kennell 43,350 #2 Posted February 16, 2023 to the We need a model number to answer your question as there are several different hubs. 3 hole 4 hole 5 hole 1" axle 1.125" axle 3 Share this post Link to post Share on other sites
Pullstart 68,405 #3 Posted February 16, 2023 @WHX?? might could fix that hub. He has a broach set to cut a new keyway. 1 1 Share this post Link to post Share on other sites
Pullstart 68,405 #4 Posted February 16, 2023 Pictures from the other post tell me it’s a 3 speed in a mid 60’s square hood, so a 1” hub and a brake drum needed too? 1 Share this post Link to post Share on other sites
Ed Kennell 43,350 #5 Posted February 16, 2023 7 minutes ago, Pullstart said: @WHX?? might could fix that hub. He has a broach set to cut a new keyway. Looks like it needs more than a new keyway. 1 Share this post Link to post Share on other sites
quent pye 16 #6 Posted February 17, 2023 15 minutes ago, Pullstart said: Pictures from the other post tell me it’s a 3 speed in a mid 60’s square hood, so a 1” hub and a brake drum needed too? Ya I need a drum brake it has high and low with 3 forward gears and one reverse gear 1 Share this post Link to post Share on other sites
quent pye 16 #7 Posted February 17, 2023 29 minutes ago, Ed Kennell said: to the We need a model number to answer your question as there are several different hubs. 3 hole 4 hole 5 hole 1" axle 1.125" axle Its a five bolt hub 1 Share this post Link to post Share on other sites
Pullstart 68,405 #8 Posted February 17, 2023 Oh, ok. Measure the axles and report back to us. Is the axle ok, or will that need replacing? Share this post Link to post Share on other sites
quent pye 16 #10 Posted February 17, 2023 41 minutes ago, Pullstart said: Oh, ok. Measure the axles and report back to us. Is the axle ok, or will that need replacing? The axle is fine it's just the hub 2 Share this post Link to post Share on other sites
Pullstart 68,405 #11 Posted February 17, 2023 Just now, quent pye said: The axle is fine it's just the hub ok. Still need the diameter Share this post Link to post Share on other sites
Ed Kennell 43,350 #12 Posted February 17, 2023 Can you post the tractor model number? It may be below the dash plate. Share this post Link to post Share on other sites
quent pye 16 #13 Posted February 17, 2023 Just now, Ed Kennell said: Can you post the tractor model number? It may be below the dash plate. Yep I will 1 Share this post Link to post Share on other sites
quent pye 16 #14 Posted February 17, 2023 Just now, Ed Kennell said: 6 minutes ago, Pullstart said: ok. Still need the diameter Yep just heading out now 1 Share this post Link to post Share on other sites
Pullstart 68,405 #15 Posted February 17, 2023 12 hours ago, quent pye said: Yep just heading out now Did you get stuck in a snow drift? Share this post Link to post Share on other sites
WHX?? 53,081 #16 Posted February 17, 2023 (edited) Yes most hubs can be saved if not wobbled out and fit fairly snug on the axle. Check the keyway and axle for damage. While your at it check the outer axle bearing and seal. Edited February 17, 2023 by WHX?? 2 1 Share this post Link to post Share on other sites
oldlineman 1,580 #17 Posted February 17, 2023 Looks like you could use the brake material also Bob Maynard has them check our vender section. 1 Share this post Link to post Share on other sites
quent pye 16 #18 Posted February 17, 2023 (edited) 16 hours ago, Pullstart said: ok. Still need the diameter Edited February 17, 2023 by quent pye Pictures 1 Share this post Link to post Share on other sites
quent pye 16 #19 Posted February 17, 2023 19 hours ago, Pullstart said: Pictures from the other post tell me it’s a 3 speed in a mid 60’s square hood, so a 1” hub and a brake drum needed too? I found the drum in my laneway 2 Share this post Link to post Share on other sites
