Crobson 20 #1 Posted January 31, 2023 I managed to lose the 3 screws that hold the bottom of the air filter box onto the carburetor. Does anyone know what size they are? I'm guessing 10-32 or 12-24 by 1/2 or 5/8. If the ones I just bought fit I'll update so the next disorganized person can replace theirs. On the lighter side, the engine is a lot happier with properly adjusted valves and a clean carburetor. 1 Share this post Link to post Share on other sites
WHX?? 54,989 #2 Posted January 31, 2023 10-32 guessing. Tip Make sure they are locked down good and close the choke when working on. 1 Share this post Link to post Share on other sites
lynnmor 8,625 #3 Posted January 31, 2023 I used blue thread locker on those screws. Any chance that the engine ate the screws? Share this post Link to post Share on other sites
Crobson 20 #4 Posted January 31, 2023 Definitely didn't eat them, thankfully. I had them in the cover on a shelf. I pulled the carb, cleaned and rebuilt it, as well as the intake and exhaust manifolds while I was getting at the valves. Turning the engine over to see the timing would have found them if they made it to the valves. I've been using blue gel threadlocker in a little pump bottle on almost everything I touch for years. I had a brake caliper bolt vanish on me a while back, darned thing was fine thread metric, $14 from the dealer. 2 Share this post Link to post Share on other sites
RED-Z06 2,716 #5 Posted February 1, 2023 Its 10-32, but length will depend on if you have the deflector or not. Share this post Link to post Share on other sites
Crobson 20 #6 Posted February 6, 2023 Delayed update, 10-32 is correct. The holes on my Nikki carb are deeper than I'd expected, 10-32x3/4 screws were the shortest I could find easily and they didn't come close to bottoming out. I'll have to add flange bolt replacements to my list, torx head if I can find them. My air cleaner box is the rectangular version, with the little intake tube from the flywheel fan housing. Other than the naked "hot rod" style, I'm not sure what other variants there are. 1 Share this post Link to post Share on other sites
