gottahavvitt 0 #1 Posted July 21, 2009 I just picked up a Kohler k241s complete with all the electrics. The guy left it attached to the frame and stripped everything else off. The motor starts right up and purrs like a kitten but I can't find out what model WH it belongs to. The spec # is 46863 and the serial # is 161020682. I am not sure about the 8 as the decal is scratched aenough to make it hard to read. I know there is a place to look this stuff up but can't remember because of my advancing case od "Sometimers disease" As usuall any help would be greatly appreciated. BTW I want to transplant it into either the 1057 or 953. This motor is electric start but not the starter gen. model. Thanks Joe :thumbs2: Share this post Link to post Share on other sites
TT-(Moderator) 1,160 #2 Posted July 21, 2009 It's out of a 1986 Wheel Horse 310-8. (tractor model # 21-10K802 or 21-10K803) Will you be keeping the gear drive starter or changing it over to the starter/generator? Share this post Link to post Share on other sites
gottahavvitt 0 #3 Posted July 21, 2009 It's out of a 1986 Wheel Horse 310-8. (tractor model # 21-10K802 or 21-10K803) Will you be keeping the gear drive starter or changing it over to the starter/generator? TT I will probably use the motor the way it is and not change it over to the starter/gen. Everything is there for an easy swap including regulator, solenoid etc Joe Share this post Link to post Share on other sites
gottahavvitt 0 #4 Posted July 22, 2009 I was just out back messin with the new motor and noticed that the block is marked K301 on the pulley side but the tag on the shroud says k241s. Are they the same block or was there an engine upgrade using the old shroud? None of my other 241s are not marked at all on the pulley side. Share this post Link to post Share on other sites
CasualObserver 3,410 #5 Posted July 22, 2009 That means the that block could be bored out to become a K301 if necessary or desired. It's common, just not noticed a lot. Share this post Link to post Share on other sites
