Doubletrouble 10 #1 Posted July 21, 2009 I'm curious as to what wheels will fit on my '71 work horse 800. Would wheels from a cub or deer fit on mine? I would like to put ag tires on it in the future but I don't want to get rid of the original wheel horse tires so I would like to find a different set of rims to mount the ag's on. Share this post Link to post Share on other sites
SKYNYRD 0 #2 Posted July 21, 2009 Hay DoubleTrouble, Ive been looking for the same info. You would think someone here on Red Square would know.?? Skynyrd Share this post Link to post Share on other sites
Doubletrouble 10 #3 Posted July 21, 2009 I was hoping. If another wheel will fit then I would like to get some 23x10.5x12 ag tires on my tractor. I think they look awsome on a horse. Share this post Link to post Share on other sites
oldandred 15 #4 Posted July 21, 2009 Ok what do the wheel look like five bolts that hold them on or a clip ring?? Share this post Link to post Share on other sites
Doubletrouble 10 #5 Posted July 21, 2009 They are 5 bolt Share this post Link to post Share on other sites
Kelly 1,033 #6 Posted July 22, 2009 Most all 5 bolt wheels will fit, from many other brands, 2 things to look for are center hole the right size, and the offset (where the center plate is welded in the outer rim/shell), most WH wheels are welded near the back of the shell, but I have cub wheels on one and bolens on another, yours being a older tractor many more will fit, when you get to the tractors with the gas tank under the fender you have less room. Share this post Link to post Share on other sites
Doubletrouble 10 #7 Posted July 22, 2009 ok, thanks for the info. I wasn't sure if other wheels would bolt up. Share this post Link to post Share on other sites
Ted Wendel 0 #8 Posted July 22, 2009 Toro part number 110680 is what I got for my 1989 414-8,they should fit yours also.They are 12" x 8.5" 5 lug. I can measure the lug circle if you need.They are silver,I don't know if they have any in off white. Share this post Link to post Share on other sites
Doubletrouble 10 #9 Posted July 22, 2009 Can I ask? How much were they? I can check the lug circle on mine but I think those would probably match up. Share this post Link to post Share on other sites
dr74go 1 #10 Posted July 22, 2009 I recently bought a set of rims for my 520-H from Kart Wheels for (I think) $90.00. I think they sell on ebay. They are white or off white and are 5 lug. As someone else stated, you need to check the backspacing and the bolt pattern. I tried Cub Cadet rims on mine and they would not fit. The backspacing was too deep. The rims I bought have a very narrow backspacing. The flange is about an inch from the inside lip of the rim. They also have the rims with the deeper backspacing. Danny Share this post Link to post Share on other sites
Doubletrouble 10 #11 Posted July 22, 2009 Thanks Danny, I'll check around and see what I can find. It's not a pressing issue. I just like the looks of them and I would think they would be better in the winter for snow removal. I have a blower to mount on the front of the horse to clear the driveway. The chains I'm sure work well but I can justify the expence this way to the wife. LOL Share this post Link to post Share on other sites
