RED-Z06 2,681 #1 Posted December 31, 2022 You really have to do it right. This is local to me for "parts or rebuild"...id say she's pretty well done. 1 2 Share this post Link to post Share on other sites
ebinmaine 74,575 #2 Posted December 31, 2022 10 bolt head? K341? If the carb's tight that's got it's own value. Metal fuel pump? PTO clutch disc? Cam maybe up for a regrind... Block is.... Tired?? 2 Share this post Link to post Share on other sites
stevasaurus 23,456 #3 Posted December 31, 2022 (edited) I'm sure you have some good parts there, but the seller could be paying you to take that boat ancher. Really, the block is shot, maybe get sheet metal. The cam may be worth something to the right guy. The carb...maybe. If I was going to be interested in this, I would have to have the same engine that needed some of those parts. Not worth much to me. Edited January 1, 2023 by stevasaurus 2 Share this post Link to post Share on other sites
RED-Z06 2,681 #4 Posted December 31, 2022 It looks like it was blown sometime around the Reagan administration then stored in a shed 12ft from the Gulf of Mexico ever since. K341 yes. I think they were wanting $80 for it.. 1 2 Share this post Link to post Share on other sites
ebinmaine 74,575 #5 Posted December 31, 2022 3 minutes ago, RED-Z06 said: wanting $80 for it.. It's worth that IIFF the carb is rebuildable Share this post Link to post Share on other sites
squonk 44,633 #6 Posted December 31, 2022 Offer $40. You still have to drive to get it. $10 worth of gas? If he doesn't budge, forget it. Carb and fuel pump is really the only value to it Share this post Link to post Share on other sites
kpinnc 15,717 #7 Posted December 31, 2022 I wonder how that even happened? Washed it while hot or something? I'd be curious what the condition of the crank and piston is in. Share this post Link to post Share on other sites
RED-Z06 2,681 #8 Posted December 31, 2022 1 minute ago, kpinnc said: I wonder how that even happened? Washed it while hot or something? I'd be curious what the condition of the crank and piston is in. Ive seen a similar failure on a K341 with ether, guy loaded one with liquid summer in the plug hole, and cycled the key...plug sparked, piston must have been at tdc or bdc because it blew the jug off the crankcase..only went up an inch or so but yeah. Share this post Link to post Share on other sites
kpinnc 15,717 #9 Posted December 31, 2022 7 minutes ago, RED-Z06 said: Ive seen a similar failure on a K341 with ether, guy loaded one with liquid summer in the plug hole, and cycled the key...plug sparked, piston must have been at tdc or bdc because it blew the jug off the crankcase..only went up an inch or so but yeah. Liquid summer... Positive uses include potato guns and NOTHING ELSE. Never thought about ether. Yep that'll do her! 1 Share this post Link to post Share on other sites
RED-Z06 2,681 #10 Posted December 31, 2022 2 minutes ago, kpinnc said: Liquid summer... Positive uses include potato guns and NOTHING ELSE. Never thought about ether. Yep that'll do her! Only thing i keep it around for is mounting tires, has no business in a small engine 2 1 Share this post Link to post Share on other sites
kpinnc 15,717 #11 Posted December 31, 2022 28 minutes ago, RED-Z06 said: has no business in a small engine Agreed. Cold, 1,000+lb cast iron diesel engines can tolerate it once in a while. Everything else not so much. Share this post Link to post Share on other sites
Shynon 7,491 #12 Posted December 31, 2022 Little JB Weld and it will be good as new. 1 5 Share this post Link to post Share on other sites
RED-Z06 2,681 #13 Posted December 31, 2022 15 minutes ago, kpinnc said: Agreed. Cold, 1,000+lb cast iron diesel engines can tolerate it once in a while. Everything else not so much. In the 6.5 diesel world we call it canned head gasket remover 😅 2 1 Share this post Link to post Share on other sites
Bill D 2,363 #14 Posted December 31, 2022 If the crank, cam, carb, flywheel, stator, and oil pan are good then it's worth $80. Try to get it cheaper of course, but get it. 1 Share this post Link to post Share on other sites
RED-Z06 2,681 #15 Posted December 31, 2022 6 minutes ago, Bill D said: If the crank, cam, carb, flywheel, stator, and oil pan are good then it's worth $80. Try to get it cheaper of course, but get it. I dont see the value in it, if it was closer..maybe but its about 2hrs round trip and rough. 1 1 Share this post Link to post Share on other sites
ebinmaine 74,575 #16 Posted December 31, 2022 Looks like it's been a display in a saltwater aquarium. Share this post Link to post Share on other sites
Bill D 2,363 #17 Posted December 31, 2022 6 minutes ago, RED-Z06 said: I dont see the value in it, if it was closer..maybe but its about 2hrs round trip and rough. Didn't see that picture. $40 tops. Not worth the long trip. Maybe if you were close. Share this post Link to post Share on other sites
ebinmaine 74,575 #18 Posted December 31, 2022 1 minute ago, Bill D said: Didn't see that picture. $40 tops. Not worth the long trip. Maybe if you were close. Can't find 16 HP single carbs much. IIFF the carb is usable it's worth the 80 just by itself. Judging by the rusty internals that's likely also no good. Share this post Link to post Share on other sites
CCW 1,442 #19 Posted December 31, 2022 Walk, no Run away. 1 Share this post Link to post Share on other sites
Lagersolut 749 #20 Posted January 1, 2023 3 hours ago, RED-Z06 said: Only thing i keep it around for is mounting tires, has no business in a small engine Nope - my Kohlers will never see a shot of ether - not worth the risk 1 1 Share this post Link to post Share on other sites
c-series don 10,563 #21 Posted January 1, 2023 12 hours ago, Lagersolut said: Nope - my Kohlers will never see a shot of ether - not worth the risk I agree with this, I only use gasoline and a little two stroke oil in a spray bottle if necessary. 1 Share this post Link to post Share on other sites
Lagersolut 749 #22 Posted January 1, 2023 (edited) 26 minutes ago, c-series don said: I agree with this, I only use gasoline and a little two stroke oil in a spray bottle if necessary. I like that idea - I've been using Valvoline carb and throttle body for years, also read reviews small shots of WD-40 are good to get one going - it's funny - my C101 sits for 3 months it's either a boost or drain the battery cranking - 416-8 is just the opposite - could sit 6 months turn key a little choke takes right off - even my newer 315 needs a little shot if it sits too long Edited January 1, 2023 by Lagersolut 2 Share this post Link to post Share on other sites
John2189 550 #23 Posted January 1, 2023 16 hours ago, ebinmaine said: Can't find 16 HP single carbs much. IIFF the carb is usable it's worth the 80 just by itself. Judging by the rusty internals that's likely also no good. It has a starter on it. 1 Share this post Link to post Share on other sites
Blasterdad 3,044 #24 Posted January 5, 2023 On 12/31/2022 at 4:49 PM, kpinnc said: Liquid summer... Positive uses include potato guns and NOTHING ELSE. Good wasp killer too, but I've found carb cleaner works even better, kills them INSTANTLY & no oily residue. It's all I use. On 1/1/2023 at 9:07 AM, c-series don said: I agree with this, I only use gasoline and a little two stroke oil in a spray bottle if necessary. Same here, 89 Oct rec gas & Klotz. 2 Share this post Link to post Share on other sites
953 nut 62,181 #25 Posted January 6, 2023 If it won't start without a squirt of whatever it is time to diagnose the problem and correct it. Share this post Link to post Share on other sites
