tractorhogg 612 #1 Posted December 21, 2022 Can I use my 54" d series tiller on my 17 hp Kubota B7100 that runs 850 rpm on high speed? Thanks 1 Share this post Link to post Share on other sites
pfrederi 18,983 #2 Posted December 21, 2022 (edited) D series PTOs were 2000 rpm. Clockwise... many big tractors are ccw PTO do not know about Kubota Tiller would be turning slowly Edited December 21, 2022 by pfrederi Share this post Link to post Share on other sites
pacer 3,177 #3 Posted December 21, 2022 Also the D's 3 point is a category '0' where the kubota is cat '1', then there the compatibility of the drive shaft - Several reasons this wouldnt work. Share this post Link to post Share on other sites
tractorhogg 612 #4 Posted December 21, 2022 1 hour ago, pacer said: Also the D's 3 point is a category '0' where the kubota is cat '1', then there the compatibility of the drive shaft - Several reasons this wouldnt work. Thanks, I forgot about the drive shaft, but I have several non PTO driven Cat 0 implements I use on the Kubota, like the Brinly 3 point double disc, box blade, and plow, I just use bushings on the pins 1 Share this post Link to post Share on other sites
tractorhogg 612 #5 Posted December 21, 2022 7 hours ago, pfrederi said: D series PTOs were 2000 rpm. Clockwise... many big tractors are ccw PTO do not know about Kubota Tiller would be turning slowly The Kubota is clockwise, yep half the speed, but then again a 540 Cat 1 tiller would be turning almost 1/4 of that speed and seems to till fine so I guess its better to go less than more...I wouldn't put a 540 tiller on a Wheel Horse, but the drive shaft alteration would be a expensive pain. Thanks Share this post Link to post Share on other sites
