CCW 1,516 #1 Posted December 7, 2022 My 312-8 has a very oily brake band. Is there a way to clean it? ccwpost 2 Share this post Link to post Share on other sites
ebinmaine 80,103 #2 Posted December 7, 2022 Are you fixing the source of the oil leak? There are those that would clean the band with large amounts of brake clean and degreaser. I've done it with mixed results. The last few years I've come to the conclusion that once a brake shoe is oily... It's bad. 5 Share this post Link to post Share on other sites
rmaynard 17,495 #3 Posted December 7, 2022 First you need to find where the oil is coming from and fix it. Then soak the brake band in a mixture of water and Dawn dishwashing liquid for a couple of hours. Scrub with a stiff brittle brush or wire brush. Rinse, and then dry with a hair dryer or put in your wifes oven at about 200 degrees. If that doesn't fix it, there is a vendor on here who sells excellent brake linings. 2 3 6 Share this post Link to post Share on other sites
wallfish 20,387 #4 Posted December 7, 2022 I just soak'm in gasoline The brake shaft seal is leaking 5 Share this post Link to post Share on other sites
rmaynard 17,495 #5 Posted December 8, 2022 1 hour ago, wallfish said: I just soak'm in gasoline You love that gasoline 5 Share this post Link to post Share on other sites
Moonshine*Connoisseur 498 #6 Posted December 8, 2022 @wallfish does it have to be ethanol free or can I just use regular pump gas ? 😂😂😂 5 Share this post Link to post Share on other sites
ebinmaine 80,103 #7 Posted December 8, 2022 13 minutes ago, Moonshine*Connoisseur said: @wallfish does it have to be ethanol free or can I just use regular pump gas ? 😂😂😂 Well that's just silly. Ethanol free of course!! 4 Share this post Link to post Share on other sites
CCW 1,516 #8 Posted December 8, 2022 2 hours ago, rmaynard said: there is a vendor on here who sells excellent brake linings. I would prefer to purchase a new brake lining. Who is the vendor? If you cannot post it on this page then can you send me a private message. The brake shaft seal is leaking and I am in the process of replacing the seal. 2 Share this post Link to post Share on other sites
CCW 1,516 #9 Posted December 8, 2022 2 hours ago, ebinmaine said: The last few years I've come to the conclusion that once a brake shoe is oily... It's bad. EB - I agree. The brakes are original from 1987 and a replacement is in order. 2 Share this post Link to post Share on other sites
rmaynard 17,495 #10 Posted December 8, 2022 (edited) 1 hour ago, CCW said: I would prefer to purchase a new brake lining. Who is the vendor? If you cannot post it on this page then can you send me a private message. A little tongue-in-cheek humor. The vendor is me. Find me in the vendor section. Bob's Wheel Horse Brake Linings and more. Edited December 8, 2022 by rmaynard 7 1 Share this post Link to post Share on other sites
wallfish 20,387 #11 Posted December 8, 2022 Gasoline easily dissolves the oil out of them but the old brake lining material isn't near as good as the new "rubber type" like Bob sells. The new stuff has much better friction properties. 2 hours ago, rmaynard said: You love that gasoline Tastes good! LoL 4 5 Share this post Link to post Share on other sites
WHX?? 57,648 #12 Posted December 8, 2022 (edited) The older ones I burn off with a small heat wrench. They seem to be made of some kind of knit material. Once it gets hot enough the oil wicks out like an kerosene lamp wick and burns off. No issues with the lining coming off so far. Betting the older ones were made of asbestos? Doubt if this would work on Bob's linings. My go to for your linings is Gorilla glue Bob. Edited December 8, 2022 by WHX?? 6 Share this post Link to post Share on other sites
WHX?? 57,648 #13 Posted December 8, 2022 18 hours ago, wallfish said: . Tastes good! LoL I'll take that shot of diesel now... 1 2 Share this post Link to post Share on other sites
Pullstart 71,016 #14 Posted December 8, 2022 22 hours ago, Moonshine*Connoisseur said: @wallfish does it have to be ethanol free or can I just use regular pump gas ? 😂😂😂 you are a @Moonshine*Connoisseur! Just use Blue Flame! Throw it back! 2 1 Share this post Link to post Share on other sites
Moonshine*Connoisseur 498 #15 Posted December 8, 2022 Ha ha ! 😂 Share this post Link to post Share on other sites
rmaynard 17,495 #16 Posted December 8, 2022 8 hours ago, WHX?? said: My go to for your linings is Gorilla glue Bob. Problem that I see with Gorilla glue is that it expands as it cures unless it is clamped tightly from one end to the other. 2 Share this post Link to post Share on other sites
WHX?? 57,648 #17 Posted December 9, 2022 5 hours ago, rmaynard said: Problem that I see with Gorilla glue is that it expands as it cures unless it is clamped tightly from one end to the other. Yes it does ooze out ... use sparingly. I do I clamp it around a spare brake drum. On 12/7/2022 at 4:51 PM, rmaynard said: put in your wifes oven at about 200 degrees. Yer missus got a cast fry pan @CCW, I don't think Bob' does... Share this post Link to post Share on other sites
CCW 1,516 #18 Posted December 9, 2022 Cast iron we have. Five of them. 1 Share this post Link to post Share on other sites
953 nut 68,201 #19 Posted December 9, 2022 On 12/7/2022 at 5:51 PM, rmaynard said: put in your wifes oven at about 200 degrees. But don't put it in the oven after washing it with gas as @wallfish does. Seriously, Bob's brake lining work so much better than the one that came on my 310-8 that I changed it even though there were no problems with the old one. 3 1 Share this post Link to post Share on other sites
rmaynard 17,495 #20 Posted December 9, 2022 7 hours ago, WHX?? said: Yer missus got a cast fry pan @CCW, I don't think Bob' does... As a matter of fact, I season all of my cast iron in the oven while my wife is away. She goes to lunch one day a week with neighbor ladies. That's a window from 11:30 am until 4:00 pm. I've also cured paint in the same oven, but that really stinks. 3 2 Share this post Link to post Share on other sites
WHX?? 57,648 #21 Posted December 10, 2022 16 hours ago, CCW said: Cast iron we have. Five of them. Ouch... 13 hours ago, rmaynard said: As a matter of fact, I season all of my cast iron in the oven while my wife is away. I've also cured paint in the same oven, but that really stinks. How's her swing with the rolling pin... 2 Share this post Link to post Share on other sites
WheelHorse_of_course 101 #22 Posted December 10, 2022 On 12/7/2022 at 9:52 PM, wallfish said: Tastes good! LoL Less filling! Share this post Link to post Share on other sites
