benjiboo 174 #1 Posted December 7, 2022 Yesterday I aquired a Brinly 38" blade and I was curious if anyone has adapted this to work on the back of a Suburban or other model with the slot hitch? Any pictures of how you did it? Would this be too much weight hanging in the air for the lift cable or would this be within a safe working load for it? The tongue is 24" long. Thanks y'all! 1 Share this post Link to post Share on other sites
oliver2-44 11,782 #2 Posted December 7, 2022 You would need a slot hitch adapter that looks like this. Not hard to make if you have a welder. You will need a lot of rear wheel weight on a Suburban to get enough traction. Then some front weight to keep the front end down. Share this post Link to post Share on other sites
Pullstart 71,366 #3 Posted December 7, 2022 except A LOT of front weight! The cable should be the least of your worries, unless it is frayed or damaged in any way. Lowell at Wheelhorsepartsandmore has high quality cables that we have tortured without fail that I’m aware of. 1 Share this post Link to post Share on other sites
benjiboo 174 #4 Posted December 7, 2022 39 minutes ago, oliver2-44 said: You would need a slot hitch adapter that looks like this. Not hard to make if you have a welder. You will need a lot of rear wheel weight on a Suburban to get enough traction. Then some front weight to keep the front end down. Yeah I have a welder and have pretty decent fab skills...I just can't seem to find the right size flat stock to use in the slot hitch. 1 Share this post Link to post Share on other sites
benjiboo 174 #5 Posted December 7, 2022 6 minutes ago, Pullstart said: except A LOT of front weight! The cable should be the least of your worries, unless it is frayed or damaged in any way. Lowell at Wheelhorsepartsandmore has high quality cables that we have tortured without fail that I’m aware of. Yeah my cable is in excellent shape. Yeah I get it about the weight. My Suburban does wheelies just taking off at idle. 😆 2 Share this post Link to post Share on other sites
Pullstart 71,366 #6 Posted December 7, 2022 Adding front wheel weights, hanging weight, fluid filling the tires, or a combination of all three would surely help, especially once you hang more weight off the back. 1 Share this post Link to post Share on other sites
Achto 32,844 #7 Posted December 7, 2022 37 minutes ago, benjiboo said: .I just can't seem to find the right size flat stock to use in the slot hitch 5/8" thick flat stock works the best but 1/2" thick will work as well. 2 Share this post Link to post Share on other sites
benjiboo 174 #8 Posted December 7, 2022 Just now, Achto said: 5/8" thick flat stock works the best but 1/2" thick will work as well. And what is the correct width? Seems like everything is either too loose or won't fit.... 1 Share this post Link to post Share on other sites
Achto 32,844 #9 Posted December 7, 2022 6 minutes ago, benjiboo said: And what is the correct width? I think it is 2", can't seem to remember that dimension off hand. A little loose will not effect things that much. You should not have to use any force to slide it into the receiver on the tractor. Some where on the forum there was a drawing with measurements for making the adapter. 1 Share this post Link to post Share on other sites
benjiboo 174 #10 Posted December 7, 2022 2" on my Suburban is too wide. Looks like 1 15/16" which is pretty odd ball to just run out and grab somewhere. 2 Share this post Link to post Share on other sites
Pullstart 71,366 #11 Posted December 7, 2022 Know anyone with a mill? Disk grinder? 1 Share this post Link to post Share on other sites
Achto 32,844 #12 Posted December 7, 2022 (edited) A little bit of time with a grinder and you could adjust a 2" wide piece. Only need to grind what goes into the slot. Edited December 7, 2022 by Achto 1 Share this post Link to post Share on other sites
Handy Don 17,562 #13 Posted December 7, 2022 12 minutes ago, Achto said: A little bit of time with a grinder and you could adjust a 2" wide piece. Only need to grind what goes into the slot. Just be sure not to taper it lest it wedge in there! 1 Share this post Link to post Share on other sites
Pullstart 71,366 #14 Posted December 7, 2022 53 minutes ago, Handy Don said: Just be sure not to taper it lest it wedge in there! If it were tapered, a little sharpie or paint marker would show you where it is getting wedged 2 Share this post Link to post Share on other sites
