95 Truck 17 #1 Posted November 25, 2022 Evening everyone, does anyone have a source for a replacement bearing and gears for this blower? I am not looking for OEM Toro but simple over the count replacements. From like THK or Timkin or skf, I am thinking there are other sources. I know I can get the chain at Tractor supply 107744 Lutco Bearing 2174 idler sprocket 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,752 #2 Posted November 25, 2022 You may be able to get a sprocket from Tractor supply but the tooth count may be different which will affect the length of chain required. The ones I see require an inner bushing to match the mounting bolt diameter. What is the 107744 Lutco Bearing or where is it located? Share this post Link to post Share on other sites
95 Truck 17 #3 Posted November 25, 2022 (edited) The 107744 bearing is the outer drive shaft or jack shaft support bearing. This is not the inner bearing near the belt. I just found this fix Edited November 25, 2022 by 95 Truck 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #4 Posted November 25, 2022 (edited) 3 hours ago, 95 Truck said: bearing I replaced those bearings with 2 bolt bearings from " Thebigbearingstore.com " but the shaft needed to be replaced also because the stock one was just a bit too short. It was rusted to crap anyway so it was OK with me. https://thebigbearingstore.com/3-4-two-bolt-flange-bearing-ucfl204-12/ They also had 3' lengths of keyed shaft at a very reasonable price https://thebigbearingstore.com/3-4-x-36-keyed-shaft/ And the sprocket https://thebigbearingstore.com/40-b-sprockets-1/ And chain https://thebigbearingstore.com/40-roller-chain/ They ship quickly and I'm satisfied with their parts and service. Cheaper than TSC Edited November 25, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
