cmyoch 35 #1 Posted November 23, 2022 I discovered that the air filter is missing from my WH Raider with the HH100. Are spares still readily available or does anyone know a good compatible alternative that will bolt and go? 1 Share this post Link to post Share on other sites
ebinmaine 74,572 #2 Posted November 23, 2022 Has the carburetor been replaced or is it the original? I ask that because a lot of the cheap Asian replacement carburetors have metric threads and incorrect spacing. Share this post Link to post Share on other sites
cmyoch 35 #3 Posted November 23, 2022 It looks to be original 2 Share this post Link to post Share on other sites
ebinmaine 74,572 #4 Posted November 23, 2022 20 minutes ago, cmyoch said: It looks to be original You could try A to Z Tractor in PA. I may have one here. I'll take a look tomorrow morning. Share this post Link to post Share on other sites
Achto 29,857 #5 Posted November 24, 2022 16 hours ago, cmyoch said: I discovered that the air filter is missing from my WH Raider with the HH100 Do you just need the filter or do you need the whole air cleaner assembly? If you only need the filter, here is one source for you. http://www.psep.biz/store/tecumseh_round_cartridge_air_filter.htm You could also get the part number that you need from the site above & do a search to find other sources. 2 Share this post Link to post Share on other sites
