857lover 291 #1 Posted November 19, 2022 so i got a d160 in a deal and it has a twin cylinder onan with no spark not a points and condenser problem i even tried putting the positive side from the coil to the battery and i’m wondering what i should check next ? 1 Share this post Link to post Share on other sites
RED-Z06 2,567 #2 Posted November 19, 2022 1 hour ago, 857lover said: so i got a d160 in a deal and it has a twin cylinder onan with no spark not a points and condenser problem i even tried putting the positive side from the coil to the battery and i’m wondering what i should check next ? If you have 12v to the coil and the other side is grounding when the points close...and you have no spark, thats generally a bad coil. Share this post Link to post Share on other sites
857lover 291 #3 Posted November 19, 2022 (edited) 54 minutes ago, RED-Z06 said: If you have 12v to the coil and the other side is grounding when the points close...and you have no spark, thats generally a bad coil. coil was just replaced maybe the guy didn’t set the gap right on the points not sure how to tell Edited November 19, 2022 by 857lover 1 Share this post Link to post Share on other sites
pacer 3,177 #4 Posted November 19, 2022 Was it running when you got it? and has since lost the spark? 1 Share this post Link to post Share on other sites
857lover 291 #5 Posted November 19, 2022 (edited) 3 hours ago, pacer said: Was it running when you got it? and has since lost the spark? no sir it hasn’t ran since i’ve had it and it was sitting outside for some time i belive Edited November 19, 2022 by 857lover 1 Share this post Link to post Share on other sites
RED-Z06 2,567 #6 Posted November 19, 2022 4 hours ago, 857lover said: coil was just replaced maybe the guy didn’t set the gap right on the points not sure how to tell You said it was not a points/condenser problem...I assumed you had already ruled them out with a visual inspection, filing, set gap, and continuity test...or something to that affect. Share this post Link to post Share on other sites
857lover 291 #7 Posted November 19, 2022 1 minute ago, RED-Z06 said: You said it was not a points/condenser problem...I assumed you had already ruled them out with a visual inspection, filing, set gap, and continuity test...or something to that affect. yeah i mean i assume if someone would put new points in they would gap them properly but i guess i’m just as dumb as them for not thinking it 1 Share this post Link to post Share on other sites
pacer 3,177 #8 Posted November 20, 2022 (edited) OK, one possibility .... points that have been outside for a lengthy time can be prone to form a ...'glaze?' on the contacts, enough to prevent connecting. If you got a volt meter you can see if there is 'magic juice' getting to the points by hooking it to the conx at the wire on the points and rotating the engine - with key on - and you shud see 12v there. If so, the you may need to get that glaze off. There is mixed feelings on using a piece if folded fine grit sand paper and dragging it across the contact points, some just use paper -- your choice. If you dont have 12v at the points then the coil is either bad or you have a bad conx. Less likely is a bad spark plug or plug wire....... They are set at .020 Edited November 20, 2022 by pacer Share this post Link to post Share on other sites
RED-Z06 2,567 #9 Posted November 20, 2022 1 hour ago, 857lover said: yeah i mean i assume if someone would put new points in they would gap them properly but i guess i’m just as dumb as them for not thinking it You'd be shocked at how often, when points were more common, that people just bolted them in and didnt know they needed gapped or filed. There was overlap...the generation that only knew points, and hated them...then my generation that knew what they were...then the next-generation who only knows how to push a button on a screen. Share this post Link to post Share on other sites
Blasterdad 3,044 #10 Posted November 20, 2022 Should be similar... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,456 #11 Posted November 20, 2022 1 Share this post Link to post Share on other sites
