metzep
onan p220 ignition module repeat failure
metzep
Hi Folks.
So  test showed module in working condition...tested on machine....then  the p220 ran  great for  about two minutes
then shut off.. so it now shows it fails the test.... so i checked the coil, the ring the woodruff/tail key  the switch,the battery..all good.....ordered a new  166-0785....module....installed paying attension ...then  ran machine for two minutes  promptly shutting down.     new  ignition module  is ..showing failure ...  how is this possible?
lynnmor
Are you following the procedures in the Onan Service Manual?
Did you test the voltage regulator to see if the correct voltage is being supplied?
Is the coil wired properly?
horseyheaven
I have something to try and it is a really cheap part.  I had this happen on. Steiner with the same engine.  Look for a little circuit breaker under the dash.  When that thing went bad it would run a few minutes until the breaker got hot.  Then, it would shut down.  I went through everything you just mentioned.  Put a new circuit breaker on and it never did it again.  It made me sick because the circuit breaker is less than $10 compared to the time and money I had invested.  I hope this helps.  Will
RED-Z06
The pickup under the flywheel is failing?
