countylinemaple 1 #1 Posted November 9, 2022 Hello all, I have been gifted a 8" moldboard plow. I just today figured out that it is a wheelhorse plow with the slot hitch. I'm sure someone here knows what parts and pieces are needed to set up my sons 310-8 with this hitch set up. It appears it uses a cable, I know the tube for that is mounted to the top of the transmission, and looks like there is a casting that goes into the pin where the drawbar hitch is now. Is there a diagram of required parts for the cable and attaching hardware at the hitch and lift mechanism? Any help would be great. Thanks Brent 1 Share this post Link to post Share on other sites
Ed Kennell 43,936 #2 Posted November 9, 2022 Wheelhorse Parts and More - RedSquare Wheel Horse Forum Check with this Red Square vendor. to the 2 Share this post Link to post Share on other sites
953 nut 63,341 #3 Posted November 10, 2022 This will give you an idea of what you'll need. Lincoln at A to Z Tractor should be able to fix you up with good used parts, give him a call. https://www.a-ztractor.com/ Share this post Link to post Share on other sites
