Bill D
Drive belt length.
Bill D
I have a GT1800 that I have swapped an M14 into.  The original drive belt is too long for the Kohler.  I tried a 7473 belt and that was too long.  I'm guessing I need an 81" belt.  Does anyone know for sure?  I'm thinking it should be the same length as a 314H?   I'm trying to avoid multiple trips to TSC with the price of gas.  Yes, I do have the correct hydro pulley on the Kohler.  Thanks.
Edited by Bill D
wallfish
That means the engine shaft is now in a different location than the original shaft was if you're using the same belt. The belt guard might not fit correctly to allow for proper belt slip when clutching.
Is it possible to reposition that shaft? Like shim it up if it's too low and / or bigger holes in the frame to slide it forward?
  • Excellent 2
squonk
Make sure the pulley on the engine is the same diameter as the old one. Also you can buy 3 or 4  different length belts at once, find the belt that works, keep all the other belts and sleeves clean and return them on your next trip out.
Edited by squonk
tomshorse4keeps
Hi Bill D.    Whenever, I need to determine, the length, of an unknown belt, I take an old #14-3 or #12-3 round extension cord, with M & F plugs removed and wrap it around pulleys, whereever the end, meets the other side, of cord, I put a piece, of masking tape and draw a line. Then measure, from the end of the cord, to the line, on masking tape, thats the length, of belt, you need. You can also use a length, of rope, but I like the extension cord, its stiffer, easier to hold and measure acurately.
On 6/5/2022 at 7:34 PM, wh5208speed said:
Changed Status to Pending
if
  • Similar Content
    • Bill D
      By Bill D
      My 199X 416H can't reach top speed.  The cam plate hits the arm where it attaches to the transmission as shown in photo #1.  Does anyone know why this happens on some tractors and not others?  Is there a way to fix it without grinding something down?
      Photo #2 shows my 1994 416H which has full linkage travel and can reach top speed.  I don't see an obvious difference between the two.
      Thanks for the help as always.
    • Bill D
      By Bill D
      I wanted a pedal control for my recently acquired GT1800.  This is what I came up with.  It still needs some finishing and I may rework the foot pedal.  It's basically bolt on other than drilling a 7/8" hole in the belt cover.  I'm also considering building an automatic neutral return if I can find the right torsion spring.  I would appreciate any input and advice.
    • CasualObserver
      By CasualObserver
      Good running 1984 GT-1800 with solid, quiet and smooth 48 inch deck. Original condition. Hydraulic lift works correctly. Great tractor. Pick up in Kasson, MN. Cash at pick up.
    • Bill D
      By Bill D
      Can I change the hoses on my GT1800 without draining the transmission?  Thanks.
