CK_wh 3 #1 Posted October 22, 2022 (edited) Hi, so I have an 8-25, model number 70044. I think the engine has gone kaput? Any guidance on the difficulty of the operation -- doesn't seem like it should be too bad? And, any ideas on a good vendor for purchasing said engine? I think it's a tecumseh. I should say, that it's leaking gas and oil, and is low on power. Assuming it needs to be replaced. Edited October 22, 2022 by CK_wh add info, correct model # Share this post Link to post Share on other sites
953 nut 62,195 #2 Posted October 22, 2022 I think most 8-25 mowers had a B&S engine and the closer your replacement engine is to the original the easier the engine swap will be. You could use any vertical crankshaft engine with the same size crankshaft but connecting wires and cables would be an adventure if another engine were used. 2 Share this post Link to post Share on other sites
Snoopy11 5,720 #3 Posted October 22, 2022 4 hours ago, 953 nut said: the closer your replacement engine is to the original the easier the engine swap will be Definitely correct Richard. The easiest swap is going to be something similar. Check this out @CK_wh https://www.ebay.com/itm/134251677050?hash=item1f4206057a:g:I~oAAOSwWvhjMfJi&amdata=enc%3AAQAHAAAAsO04nB3LsJ4F4KiBG%2BB0h0rPmHaZ%2FSWwxFjA6YWh6c0CcBAV2rbqjkzkhqCCYi3hfBesXG12SqjGLQTL%2BOWxOi9WLgGUBEq09U2ms599zbuyW8kVV5PWGmHMCm%2BCDnQnvrGpJJrcLwYwdCnx%2FrW%2BW0uKvOwpOguHzlWrZLexbQ0D7Njkl1rEjikcysbGC6JlbF0L8nuwkYruvIck0MSNolpn2ftlpBUzKHFac64lFObH|tkp%3ABk9SR4b_14eAYQ Don Share this post Link to post Share on other sites
CK_wh 3 #4 Posted October 23, 2022 You were right -- it is a B&S. 1 Share this post Link to post Share on other sites
