chalky493@yahoo.com 10 #1 Posted October 20, 2022 Do have to split the transmission to install axle seals 1 Share this post Link to post Share on other sites
Pullstart 60,216 #2 Posted October 20, 2022 No you do not. This is assuming you don’t need bearings too. Generally when they wear excessive, they take out the seals. 2 1 Share this post Link to post Share on other sites
Ed Kennell 36,110 #3 Posted October 20, 2022 2 hours ago, chalky493@yahoo.com said: Do have to split the transmission to install axle seals No, you must remove the hub and then you can pull the old seal out with a seal removal pick or a small screwdriver. But first you should check the bearing for wear by pushing on the axle. There should be no up/down or front/back movement. In/out is OK If the bearing is bad, you must split the case and replace the bearing or the new seal will also leak. 3 1 Share this post Link to post Share on other sites
chalky493@yahoo.com 10 #4 Posted October 20, 2022 Thanks I'll check the bearings for play . Any help on the part number for seals and bearing much appreciated ! Thanks again 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,551 #5 Posted October 20, 2022 Here is an illustrated parts list. Then go to the top of the transmission forum and some charts are posted to lists of today's seal and bearing numbers available locally. We also have a vendor that can supply. 1 1 Share this post Link to post Share on other sites
chalky493@yahoo.com 10 #6 Posted October 20, 2022 Thanks 1 Share this post Link to post Share on other sites
953 nut 52,268 #7 Posted October 20, 2022 10 hours ago, chalky493@yahoo.com said: help on the part number for seals and bearing much appreciated Presuming your axles are one inch the seal would be SKF-9815 and the bearing would be KOYO M-16121. Share this post Link to post Share on other sites
ebinmaine 63,563 #8 Posted October 23, 2022 On 10/20/2022 at 7:37 PM, 953 nut said: Presuming your axles are one inch the seal would be SKF-9815 and the bearing would be KOYO M-16121. 1977 B80 8 speed could be the larger 1⅛ axles. Share this post Link to post Share on other sites
953 nut 52,268 #9 Posted October 23, 2022 17 minutes ago, ebinmaine said: 1977 B80 8 speed could be the larger 1⅛ axles. OK. I was going by the numbers I used on a one inch gear box. Here are the charts I saved from a previous post. 1 Share this post Link to post Share on other sites
chalky493@yahoo.com 10 #10 Posted October 24, 2022 Anybody have a part number for the axle needle bearing for a 1977 B80 8 speed 1 1/8 " 1 Share this post Link to post Share on other sites
ebinmaine 63,563 #11 Posted October 24, 2022 In the 3rd chart above see where I've circled. Lowell at Wheelhorse Parts and More will have that and they're available at a GOOD local parts store. Share this post Link to post Share on other sites
