BBELL94 25 #1 Posted October 10, 2022 Just picked up a non running 520-8. Has 588 hours on it. Paid $500 for it. Previous owner took the flywheel off trying to diagnose a no spark issue. Did I do alright on this deal and how big of a project is it to put the flywheel back on? Looking forward to getting this beast of a tractor running. Share this post Link to post Share on other sites
Sparky-(Admin) 23,903 #2 Posted October 10, 2022 Can’t say if it’s a good deal or not since it’s a non-runner. If you get spark back and it runs good then yes. If you dump hundreds into getting spark back and it runs crappy, smokes, knocks or even worse.. only runs on one cylinder it was a lousy deal. Any attachments?? 3 Share this post Link to post Share on other sites
BBELL94 25 #3 Posted October 10, 2022 34 minutes ago, Sparky said: Can’t say if it’s a good deal or not since it’s a non-runner. If you get spark back and it runs good then yes. If you dump hundreds into getting spark back and it runs crappy, smokes, knocks or even worse.. only runs on one cylinder it was a lousy deal. Any attachments?? It came with a very nice 48" deck. Share this post Link to post Share on other sites
lynnmor 8,145 #4 Posted October 10, 2022 The flywheel is easy to put on, one bolt in the center torqued to 55 lb. ft. The blower tin is a bit of a pain. Before torquing it back up, test the ignition module using the Onan Service Manual available in the manuals section. Share this post Link to post Share on other sites
BBELL94 25 #5 Posted October 11, 2022 1 hour ago, lynnmor said: The flywheel is easy to put on, one bolt in the center torqued to 55 lb. ft. The blower tin is a bit of a pain. Before torquing it back up, test the ignition module using the Onan Service Manual available in the manuals section. I seen some timing marks on the block, do I have to time the flywheel somehow or perhaps maybe its keyed? Share this post Link to post Share on other sites
WHX?? 53,081 #6 Posted October 11, 2022 It's keyed ... down load the manual and study it ... it will tell you how to trouble shoot the no spark. There are also narks on the shroud that indicate firing points. 1 Share this post Link to post Share on other sites
kpinnc 15,955 #7 Posted October 11, 2022 If you can check compression on both cylinders, and they're within limits of the manual- you can relax a little. Always been a rule of thumb for me. If it has compression, I can get it to run... 1 Share this post Link to post Share on other sites
Ed Kennell 43,364 #8 Posted October 11, 2022 9 hours ago, kpinnc said: If it has compression, I can get it to run... Yep, just add fuel and fire. Share this post Link to post Share on other sites
Pullstart 68,406 #9 Posted October 11, 2022 They sure are beasts! Hopefully you can get it up and running in no time Share this post Link to post Share on other sites
cafoose 3,499 #10 Posted October 11, 2022 Since you have no spark, before you put the flywheel on, make absolutely sure the module is working properly. If not, you will be removing it again and it's a PIA to put all the shrouds on 2 Share this post Link to post Share on other sites
JoeM 9,061 #11 Posted October 11, 2022 If you find out that the Ignition Module is bad best to be patient and shop around. some go north of $100. Sometimes flea bay has some finds. Cummins owns Onan and they are very proud of their parts. Share this post Link to post Share on other sites
lynnmor 8,145 #12 Posted October 11, 2022 11 hours ago, BBELL94 said: I seen some timing marks on the block, do I have to time the flywheel somehow or perhaps maybe its keyed? There is a key, be sure to put it in correctly so the tail of it engages the trigger ring. Share this post Link to post Share on other sites
BBELL94 25 #13 Posted October 11, 2022 Thank you all for all the advice!! Share this post Link to post Share on other sites
BBELL94 25 #14 Posted October 12, 2022 On 10/11/2022 at 8:51 AM, JoeM said: If you find out that the Ignition Module is bad best to be patient and shop around. some go north of $100. Sometimes flea bay has some finds. Cummins owns Onan and they are very proud of their parts. How do you go about testing the ignition module? Is it in the manual? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,777 #15 Posted October 12, 2022 1 Share this post Link to post Share on other sites
JoeM 9,061 #16 Posted October 12, 2022 Might try this, I also have put a ohm meter on the unhooked module wires and should get .4 to 2 ohms reading. Share this post Link to post Share on other sites
