Gary S Minnesota 61 #1 Posted October 10, 2022 I finally received the micro switches for the PTO and installed this week. I’ve sorted through the “rats”nest of wiring ( most of which was disconnected and in a ball). and believe I have it routed correctly. The neutral safety switch appears to have been jumped as does the seat safety switch. I’m thinking there should be another safety switch at the brake or parking brake but have not spotted any wiring or mount points for a switch? At any rate I get not action to the starter when turning the key. I can get the starter to turn if I jump the solenoid. I confess I know just enough to probably get myself into a bit of trouble! Anyone have a suggestion as to what I should be looking at? Thanks for any help! Gary in Minnesota 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,722 #2 Posted October 10, 2022 In the wiring Demystification is a set of drawings for each major circuit with one being the starter. Easy to follow what is necessary for it to work so download that file. This is the file name to download - p7-127 1988-1989 516-H 520-HC Color.pdf 2 2 Share this post Link to post Share on other sites
Gary S Minnesota 61 #3 Posted October 10, 2022 Thank you. I will download and take a look! 1 Share this post Link to post Share on other sites
Lee1977 7,379 #4 Posted October 10, 2022 The safety switches for the parking brake and the motion lever are mounted under the plate, Share this post Link to post Share on other sites
Gary S Minnesota 61 #5 Posted November 7, 2022 Up date on 516 H. Did get it running, very smoothly I might add. Finally traced the problem to the neutral safety switch which the PO had jumped with plug in connectors. Connectors appeared to be clean and in good condition but one side was obviously not. Replaced the connection temporarily and it fired up as expected. Now have to source a female connecter to finally wire into the existing neutral safety switch found on the underside of the plate as mentioned. Thank you all for the help!! Gary 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,722 #6 Posted November 7, 2022 Thanks for the update. We throw out suggestions and nice to hear what sticks. 1 Share this post Link to post Share on other sites
