NCWHowner 14 #26 Posted October 21, 2022 (edited) On 10/8/2022 at 3:28 PM, NCWHowner said: Thank you very much. This one is a ‘71 so I guess I’ll be pulling the side case off the motor and see what’s going on. Like I said in the original post I got this thing as a basket case and for the $150 I gave for the whole deal if I have to put some parts in it, it doesn’t hurt my feelings much. Finally, getting around to tearing this thing apart and this is what I found this afternoon after work. I purchased the new gear, but I held off on the control arm. not sure if that’s what I would need. Looking back at the pictures that you posted. It seems they are different unless there is just a new design and I am missing something. Appreciate all the help and thank you very much looking forward to getting this thing running! Edited October 21, 2022 by NCWHowner Share this post Link to post Share on other sites
ebinmaine 80,292 #27 Posted October 21, 2022 34 minutes ago, NCWHowner said: Did you ever make any traction on rebuilding your fuel pump? Mine has been good with no leaks so far. I got the parts. Likely won't be able to mess with that for a bit. Pole barn is nearing completion so we'll be spending time moving workshops around. 1 Share this post Link to post Share on other sites
RED-Z06 2,720 #28 Posted October 21, 2022 51 minutes ago, NCWHowner said: Finally, getting around to tearing this thing apart and this is what I found this afternoon after work. I purchased the new gear, but I held off on the control arm. not sure if that’s what I would need. Looking back at the pictures that you posted. It seems they are different unless there is just a new design and I am missing something. Appreciate all the help and thank you very much looking forward to getting this thing running! https://www.ebay.com/itm/144716507663?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=5gKIs7WRTnG&sssrc=2349624&ssuid=Z0V4Uge1Tf6&var=&widget_ver=artemis&media=COPY 1 Share this post Link to post Share on other sites
