Snoopy11 5,731 #1 Posted September 29, 2022 Hey guys, So... I'm trying to find the correct spark plug for the engine on the 718-Z. The spark plugs on it are not in terrible shape once I remove them... but I can BARELY read the numbers on them on the outside... I think it says Autolite #26? I just wanted to verify this with you guys before I buy some new ones... I think those are the correct plugs... but I would appreciate any advice that you guys can give... Don Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,920 #2 Posted September 29, 2022 Operator manual shows Champion RV17YC 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #3 Posted September 29, 2022 22 minutes ago, gwest_ca said: Operator manual shows Champion RV17YC Yes, I saw that in the manual... but couldn't locate a cross reference. BUT... I just found a cross reference, so on the M18 you can use: AUTOLITE 26 CHAMPION RV17YC NGK UR4 Don 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,920 #4 Posted September 30, 2022 Cross reference will give you plugs with identical physical characteristics but you should go the plug manufacturer's catalog to get the correct plug heat range. The plug maker knows best what works in the application and the cross reference does not always reflect that. 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #5 Posted September 30, 2022 56 minutes ago, gwest_ca said: you should go the plug manufacturer's catalog to get the correct plug heat range. The plug maker knows best what works in the application and the cross reference does not always reflect that. I hadn't thought about that... Don Share this post Link to post Share on other sites
