KDH
D160 Rear PTO
KDH
First time posting, would like to know if someone knew the size of the roll pin that hols the coupler on the shaft for a D series PTO. Diameter and length.
Thanks, KDH
.5racer
https://lookup3.toro.com/partdex/index.cfm
Does this help ? My guess would be as long as the width of the coupler, Size?,,,, should be a tight fit with a spring or roll pin , if loose , drill to next bigger and install a new one. Note,, drill assembled for best line up through originall hole. Hope I have helped.
