  • Please Read
  • 212-5 Mower 37" Deck or parts
    TBH
    • Active
    Need Spindle assembly for 35-37SL02 37" Deck. Will also consider entire deck but mainly need one, or both spindle assemblies.
    The pulley & shaft, which is one piece to the best of my knowledge, if fused to spindle. I had someone with a press try to break it down but wouldn't budge. I'm assuming the entire pulley and housing is a waste which is why I'm hoping to find the entire assembly (including pulley/shaft).
    User Feedback
    76c12091520h
    Posted
    Private message me here, or call/text during normal business hours:
    Share this comment
    Link to comment
    Brockport Bill
    Posted
    hi all - - I am confused by the photos shown above - i have a 37 sd mower deck from my 312-8 with bagger - its model 05-37sc01 -- i understand its not identical to a 35--37SL02 deck - but both of which have the spindles above the deck --- however, i have looked up each model and compared the spindles to the online diagrams shown for the poster thread shown here...............looking at both diagrams - in each case i see the part number 106067 (cap/cup/cover ) would be underneath of the deck - - or the bottom of the spindle shaft between the spindle and the shaft blade nuts - in neither of the manufacturer OEM diagrams online do they show a 106067 on what would be the "top" of the spindle shaft under the top pulley? The photos you show would suggest the bottom bearing is exposed to the cutting area with no "protection" for the lower bottom bearing ? What am i missing or misunderstanding? thanks - thinking ahead for my 37 deck what would price be for a new spindle unit? i did a deck restore of my deck but used the original oem spindles from 1989
    Toro 05-37SC01 - Toro 37" Side-Discharge Mower Deck (1986) Side Discharge Mower-37 In. (94 Cm) Vehicle Identification Number 05-37sc01  05-37sc02 2
    Toro 35-37SL02 - Toro 37" Side-Discharge Mower Deck (1990) Side Discharge Mower - 37" (94cm), Vin 35-37sl02 2
    Product photo of Wheel Horse Mower Deck Spindle
    Share this comment
    Link to comment
    Yeah, the spindles on my deck are different. I uploaded photos and added additional text to my original post.
    Share this comment
    Link to comment
    76c12091520h
    Posted (edited)
    It's just that the spindle shaft is installed upside down in my pictures.....you're not missing anything
    Edited by 76c12091520h
    Share this comment
    Link to comment
    76c12091520h
    Posted
    Apologies for the earlier confusion; this is the spindle assembly for a 37" deck on a vertical shaft Whorse( 7.5" shaft) , you would also need the spindle pulley #113049 ( which I am sold out of) . The pulley and shaft are separate pieces.
    Share this comment
    Link to comment
    Brockport Bill
    Posted
    Ahhh thanks..I thought that might be the issue
    Share this comment
    Link to comment
    I'll need pulley # 113049 also. That appears to be the last piece to this journey. Also mentioned before but wasn't positive if the the tube portion underneath the pulley is part of the pulley or not. Didn't see an item/part# for a separate piece. No luck on ebay, etc. Thanks for the feedback thus far.
    Share this comment
    Link to comment
    76c12091520h
    Posted
    That is how that pulley is made, all one piece , not a separate tube
    Share this comment
    Link to comment
    Joe Warren
    Posted
    I believe I have a NOS 113049 pulley. I will check on Monday.
    Joe
    Share this comment
    Link to comment
    Joe Warren
    Posted
    I have one NOS pulley. I will PM you.
    Joe
    Share this comment
    Link to comment
