  • Please Read
  • Power King Loader
    S416-8
    • Active
      Price: $2700 0b0
      Contact: sgilbert14@gmail.com
    I picked this up to complete 2 projects that I needed the loader for. Now that I have them done I’ll be letting it go. Can test it out if serious
    1) Has a rear lift on it but not a true 3-point although there is a conversion kit available.
    2) Has close to 450 lbs of wheel weights per side
    3) Rear tire chains
    4) I changed the fluids
    5) Comes with a 2nd digging bucket
    Works great just finished what I bought it for. Owned it for about 4 months.
    $2700 obo
    Spec sheet  https://www.tractordata.com/lawn-tractors/001/8/3/1832-economy-power-king-14hp.html
    I was told that the total weight is in the 2200-2500 range.
    Will add pics tonight but have them on the craigslist add
    https://ithaca.craigslist.org/grd/d/richford-power-king-tractor-loader/7899427053.html
    also have other things for sale there as well.
    • Excellent 2
    User Feedback
    Pullstart
    Posted
    Not knowing much about this brand myself, can you tell more about the tractor too?  HP, transmission, top gear speed possibly?  Nice rig!
    Share this comment
    Link to comment
    squonk
    Posted
    K321 engine, 3spd Crosley trans. Automotive clutch. Dana  5.17 to 1 rear axle. Bull gear final drive 10.3 to 1
    Share this comment
    Link to comment
    S416-8
    Posted
    Thanks.. never sure what to put in these listings
    Economy Power King 14HP tractor photo
    1968 - 1977
    Model year 1968-19721973-1977
    Garden tractor
    Transmission options
    3-speed gear
    9-speed gear - does not have this option but can be added
    Transmission
    Transmission Borg-Warner T92
    Type shaft-driven gear
    Gears 3 forward and 1 reverse
    Clutch 152.4mm mechanical dry disc
    Speeds
    With 8.00-16 rear tires. Speeds for 24-inch tires are about 20% faster.
    Power King 14HP T92 shaft-driven gear speeds
    Transmission
    Gears 9 forward and 3 reverse
    Tandem transmission option adds a second gearbox inline with the original.
    Engine Detail
    Kohler K321S
    gasoline
    1-cylinder
    air-cooled horizontal-shaft
    Displacement 512 cc
    31.27 ci
    Bore/Stroke 3.50x3.25 inches
    89 x 83 mm
    Power 14 hp
    10.4 kW
    Rated RPM 3600
    Torque 23.8 lb-ft
    32.3 Nm
    Torque RPM 2200
    Starter electric
    Starter volts 12
    Oil capacity 2.5 qts
    2.4 L
    Loader
    500 lbs lift (full at pin)
    226 kg
    65 inches height (at pin)
    165 cm
    41 inches clearance (dumped)
    104 cm
    Bucket width: 32 inches
    81 cm
    Share this comment
    Link to comment
