jellyghost 378 #1 Posted October 29, 2017 I have a C-101 with a 42 inch deck. The zerk on the center spindle was sheered off. I read some old posts, and it seems that I can replace it with sealed bearings and close the shorn zerk hole. This seems like the easiest solution to my problem. But... I can't determine the best bearings. This is an older deck before they starting using metric. In addition, I would like to replace the deck belt and the pto belt. How do I find the correct belts? Thank you! Share this post Link to post Share on other sites
daveoman1966 3,611 #2 Posted October 29, 2017 (edited) Is this you deck spindle...item 21 ...it is part # 108849 and I have a good one in my hand that I can put in your mailbox for $47... with NEW keyway and top Grease Zerk. Edited October 29, 2017 by daveoman1966 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,499 #3 Posted October 29, 2017 May not be the deck you have but the belts should be the same. Notice one is side discharge and the other is rear discharge - different belts. Click on the pictures. Garry 1 Share this post Link to post Share on other sites
jellyghost 378 #4 Posted October 30, 2017 Thank you for the responses! I have another deck I am not using, so I could steal a spindle off of it. But... I wanted to know what type of bearings I should order. Any suggestions? Is there a better name brand? Thanks! Share this post Link to post Share on other sites
