Duramax7man7 506 #1 Posted September 1, 2017 Anyone ever experience these breaking at the upper pin? If so, is it common? Share this post Link to post Share on other sites
R. L. Addison 300 #2 Posted September 1, 2017 I put in a 3/8" grade 8 bolt with a nut on each side of the lift bar. Problem never occured again. The head could be cut off & a hole drilled in it if you want to do an easier install. BUT, I did not give it a lot of side to side play, as that is leverage & stress. Just .010 -.015, with a close tolerance hardened washer. 1 Share this post Link to post Share on other sites
