ilovemywife675@gmail.com 0 #1 Posted August 20, 2017 Iso a fuel pump for a 1964 854 any help is very appreciate Share this post Link to post Share on other sites
Terry M-(Moderator) 2,327 #2 Posted August 20, 2017 You May have better luck finding your fuel pump by placing a wanted ad in the classifieds section... http://www.wheelhorseforum.com/classifieds/wanted/ Share this post Link to post Share on other sites
ilovemywife675@gmail.com 0 #3 Posted August 20, 2017 Thanks Terry posted it there to Appreciate the help Share this post Link to post Share on other sites
953 nut 69,744 #4 Posted August 20, 2017 (edited) If you have an original pump you want to rebuild to keep your authentic then this link will be helpful for the parts to rebuild your pump. http://www.then-now-auto.com/product-category/fuel-pump-kits/kohler-fuel-pump-kits/ If you just want to get it operational then an electric low pressure fuel pump is the answer. You can find lots of them on eBay for less than $ 10.00. Be sure to mount it low on the frame and you can wire it to the "+" side of your ignition coil with a 10 amp fuse in line to protect it. Edited August 20, 2017 by 953 nut 4 1 1 Share this post Link to post Share on other sites
