Chris G 3,274 #1 Posted August 11, 2017 Was wondering if anyone here has got a a111 or a81 with the 32 in side discharge deck. That you could take a picture of how the rear deck guide hooks up. Anything would be great. Thanks ahead of time. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,499 #2 Posted August 12, 2017 Would a parts illustration help? Garry 1 Share this post Link to post Share on other sites
Chris G 3,274 #3 Posted August 12, 2017 Thanks for that. I had the manuals downloaded. But I cant find no info on part 14 or 16. I just need to know a length and dimension of the piece. And then I can figure the sleeve out. But thank you again. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,499 #4 Posted August 12, 2017 Item 15 are the two nuts on the rod which are 1/2-13 thread which is coarse thread with a nylon insert to lock them. It calls for two of item 14 rod but only see one. Is there another one somewhere? Garry 1 Share this post Link to post Share on other sites
Chris G 3,274 #5 Posted August 12, 2017 Thanks! I got frustrated looking up the part number for part 14 and didn't even think of looking at the eslok nut size. Now I can get this together all the way. Also the manual I got only calls for one item 14. But again thank you for your help. It's very much appreciated. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,499 #6 Posted August 12, 2017 I don't know what you are working with because I've never seen one. You might be able to use a long 1/2" bolt and cut the head off. I used something similar as a winch cable fairlead but mounted 8 feet from the winch. Oiled up the bolt and slipped a short length of 1/2" PVC electrical conduit over the bolt and retained it with a cotter pin. 1/2" schedule 40 water or gas pipe has the same dimensions - .840" OD and .622" ID. 1/2" copper has a 5/8" OD K weight copper is .528" ID L weight copper is .545" ID M weight copper is .569" ID Maybe you could leave the head on the bolt. Garry Share this post Link to post Share on other sites
Chris G 3,274 #7 Posted August 12, 2017 Ya I think I'm connaught get a carriage bolt put a sleeve on it and then put the double nuts on. So that way I can adjust the length and get it dialed in. But again I do appreciate the help. Share this post Link to post Share on other sites
