Joplin
wheel horse runs then dies
Joplin
Have a wheel horse 314 8 speed. Ran then would quit, but had gas and spark.
Ran good when it ran.seems like an electrical issue. Can i disconnnect some stuff to manually start it, and bypass any cutoffs? Or switchs that may be bad?.
rmaynard
Might be a clogged gas cap vent. Next time it stops, loosen the cap and see if that corrects the problem.
953 nut
:WRS:     Can you, yes! Should you remove safety switches, absolutely not! I had the same problem with my 312-8 a few years back and a new fuel cap cured it. If the vent isn't working a vacuum develops in the tank as fuel is removed.
neil
I have a similar problem with my c81 , difficult starting, runs & drives for a while then dies , then difficult to start again ,, my first port of call was to check the small filter in the gas tank which on inspection was clogged with rust  so removed the filter and it did run a little better so I'm now guessing that the problem may be the lift pump diaphragm may be worn and is no pulling enough fuel through .
i don't know if this would be a similar problem that you have or whether yours is electrical issues but it's worth looking into .
i removed the small bung tap from the fuel tank under seat
good luck
DennisThornton
Does is stop like you turned the key off or like it ran out of gas?  Die instantly or sputter a few and then croak?
Instantly suggests electrical, either spark or a safety switch.  Sputters suggests fuel.  The fact that it will start again suggest starving for fuel somehow.
Edited by DennisThornton
Dan.gerous
My 125-8 is doing this now :-(
Seems like it's ignition issue, but fuel visible in filter seems slow to fill and its happening at high revs. Choke keeps it going for a little longer.
Will pull the carb and see if it's full of gunk.
Always happens just as I'm about to head away for 2 weeks.
953 nut
Check the vent in your fuel cap. As gas is being removed from the tank a slight vacuum will be created inside the tank if it is not vented. Remove enough gas and the fuel flow stops.
Dan.gerous
Will try that, it's fine messing about with the trailer, problem only seems to happen when mowing - hopefully it's that simple. Thanks 👍
Dan.gerous
Took carb off, all clean, put it back on with fuel cap off, same problem.
Turned engine over with carb off to check pump and it pumped fuel out no problem at all.
Just dies after a few minutes.
Must be electrical :-(
Dan.gerous
Watching it run this morning, goes for about 2 minutes at full throttle then surges and dies.
The clear fuel filter is full at the start, then empties followed by the surge. After a few minutes with engine off the filter fills again.
There is already quite a bit of crud in the new filter, so that might be the problem. Trying to find another one at the moment, it's packed in a box somewhere!!
lynnmor
Sounds like you need to flush the fuel tank and then replace the fuel hoses and filter.  Also, check your gas can for crud.
Dan.gerous
It has new fuel lines, tap and filter but yes, there must be something in the tank - carburetor was clean as well.
It just looks like it is starving itself, won't start immediately after stopping, but I think that's due to the fuel being all used up in the lines. Away tomorrow so probably won't be able to get the tank off until I get back, but at least its a simple enough task.
Hate having to use the hand mower, and no other wheelhorses on the property anymore!
Dan.gerous
Managed to get half an hour free, fuel tap completely blocked with sediment. Got it off, blew out with air, did a temporary quick clean of tank and threw it all back together.
Mowed top lawn without missing a beat  👌 😁
Poor little machine, it gets so frustrating sometimes when they don't run properly  - but it's always something simple.
Right, got to mow bottom lawn then take our big feed trailer apart. Already put new kickboards in kitchen, hung a door, fixed another door and packed some more stuff.
Last day home is always busy - car loaded as well :-)
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
      ONLY 419hrs
      FEATURES:
      Newer Agro Tires on Rear & Solid Front Turf Tires.
      Wheel Weights on rear.
      Fully Swapped Forward Swept axle and Steering off of 520h.
      New Tractor Supply Adjustable Seat.
      Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
       I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      Asking >>>>> $1,099 OBO <<<<<<<
      (248) 943-8634 Text or Call.  God Bless.
    • Little Red Horse
      By Little Red Horse
      I am selling a 1970 Wheel Horse Electro 12. It is in *working condition*.
      It has AG tires and a mid-mount blade from wheel horse.
      It also has a front mounted generator that currently doesnt put out power. It has been in the barn quite a while, so it may be a corroded connection,  not sure. Although there's not too much that goes wrong with them.
      The tractor has been a great one for me. The last 6ish 7ish years that I've had it where I lived it brought the gravel back up my driveway for me every time it rained. In the last few months, it would run for 20-30min then die.
      I was moving at the time so just didn't have the time to look at it. And it seems I still don't. Where I am currently I don't have a place for it. I don't want it setting out and deteriorating. So here we are.
      Please contact me by text or email.
      Thanks for looking!
    • ohiofarmer
      By ohiofarmer
      i know that there is ebb and flow with market conditions, but I have been seeing bargain 520 and c-160 prices more common. I recently saw a c-160 like model on a place other than here that was close by, but i did not get a chance to see it as I was still on a medical tether getting care. i say c-i60 like model because it was a series of numbers like 4455 or somesuch .Tractor had the k series engine clearly a sixteen HP and came with a decent looking deck and pusher blade. i called my buddy Jay and told him for the $250 ask , he better hustle after it. i really do not know if he did.
        I also have been seeing 520s and such lower than I can remember as well as the D series..My theory is that people experiencing paycheck to paycheck living are increasing in number.
      You even are seeing a lot more older trucks like square bodies and especially big blocks than you did before. we used to see this a lot in new trucks when fuel prices hit records.
      i am not claiming expert status on this, but it seems to be trending this way one county next to indiana and 90 miles North of the Ohio River.
       Tell me what you are seeing out there and what you think.
           Edit:  Jay and I ran up to buy Bob Ellison's tractor in MI.  Bob was very nice to deal with and included his "last seat"   I got super lucky buying my first C-160 that did not start and another one shortly dropped in to keep it company. The tractor described above was listed for only two days and was gone
    • Donavon
      By Donavon
      Just curious what is the heaviest for a future project.
