Hukah
Engine swap and mod
Hukah
I bought a great engine of CL for $20 (Briggs 5.5hp).
it was on a snowblower, however, and has no throttle or choke control from the driver seat.
i got a choke control hooked up, but the throttle control is being finicky.
i am mechanically apt, but not familiar with all the different intricacies of different units and I'm assuming the way this type of engine works is interfering with my new linkage I installed?
anybody got any tips I can try to get this working properly?
Hukah
For anybody interested in the follow up, I have since learned that this engine is an internal governed type, and that is why it is not compatible with a throttle cable.
I need to find a new engine.
Case closed.
  • Similar Content
    • Hukah
      By Hukah
      I need to re-power my 552.
      The only thing I can afford is a 3/4 shaft job.
      I know I'll have to change pullies, but am I going to run into problems, seeing as the original was a 1 inch shaft?
    • Hukah
      By Hukah
      Sorry for all the 'newbie' questions, guys, but no one has told me to take a hike yet so I'll push my luck with another (likely) redundant question; What is the correct drive belt size for my 552, anybody know?
      And an aside; Does the mower deck operate on the same drive belt, or is that going to be a 'take-off' pulley next to it (I am painting it so I can't align it up to tell ATM).
      Thanks again.
    • Hukah
      By Hukah
      I am going to rebuild my H55.
      i am taking pics to remind me where it goes and what it looks like, but the fuse block had been disconnect years before I got it.
      can someone explain the wiring to/from this block?
      is it possible to put lights on this electrical system?
      iver just about got this thing back on the job thanks to you all.
      i just tried to upload a pic and it won't let me.
      ill post one from my computer soon.
    • Hukah
      By Hukah
      Now that I've got the red and black painted, I'm painting the whites and just now getting cold feet while looking at the bas-relief WHEELHORSE lettering across the top of the grill.
      any tips/pointers as to the best approach to this task?
      Thanks for all the help you guys bring, I don't think I could have gotten this far without you.
    • Hukah
      By Hukah
      I didn't take the trans apart when I restored my 552.
      the last time this thing actually worked was about 16 years ago, and the trans worked fine then.
      whats happening now is, with the engine running I step on the brake but the drive pulley keeps spinning, locking me out from putting it into any gear.
      anybody know what I'm up against?
