Hendricksn 7 #26 Posted February 7, 2015 And the Key start has no M post. Just I B S R V 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,533 #27 Posted February 7, 2015 And the Key start has no M post. Just I B S R V There is the start of your problem - wrong switch. The original is part number 111215 replaced by 103991 at any Toro dealer. A Napa replacement is 7-01893 Don't get them mixed up because the only difference is the I on one and the M on the other. You must use the M. That should eliminate the short at the pto switch. Let us know what happens next. I hope no further damage was done. Garry 2 Share this post Link to post Share on other sites
Hendricksn 7 #28 Posted February 8, 2015 Well I put the new switch in and nothing happened. Now I have nothing. As if the key start doesn't work at all. And it's the one from Napa Share this post Link to post Share on other sites
Hendricksn 7 #29 Posted February 8, 2015 Like when I turn the key. It's as if nothings happening. And when I jump the solenoid no spark Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,533 #30 Posted February 9, 2015 Use this diagram to test the starter circuit. You can see where the power goes to get from the battery to the starter. Make sure both battery cables are connected to the battery. Follow the power with a test light or voltmeter starting at the 25 amp fuse that powers the red wire to the ignition switch. There are two 25 amp fuses so make sure both are good. From now on remember the key must be in the START position when you make each test. The pto must be OFF When you get to the clutch switch the pedal must be down to close that switch. If you have power in the Lt Bu wire at the relay you can assume to pto switch and clutch switch are working properly. Re is red wire Ta is tan wire Lt Bu is light blue Dk Bu is dark blue Pu is purple If you do not have power at both oil level switch wires with the key in the START position check the oil level in the engine. That is a magnetic float switch in the base of the engine. If it needs to come out read the special instructions on how to get it out without causing damage to the switch. It is fragile. Oil level switch instructions Let us know what you find and we will continue. If you click on the diagram it will enlarge. Garry Share this post Link to post Share on other sites
Hendricksn 7 #31 Posted February 9, 2015 Well there's power going into the switch via the red wire. And the 25 amp fuse is doing its job. But with the switch in the off position there's positive power coming out of the 2 dark blue wires. There's no power going out. In any of the wires. And the 15 amp headlight fuse is also good. And there's still nothing going on when you turn the key Share this post Link to post Share on other sites
Hendricksn 7 #32 Posted February 10, 2015 And there's no light blue or purple at the key start. Just pink and white with a red dot Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,533 #33 Posted February 10, 2015 Here is what the wiring at the back of the ignition switch should look like. #1 Dark green (Rectifier) #2 White (Accessories) #3 Dark blue (Magneto) #4 Tan (Starter) #5 Red (Battery) This is how they should be positioned in the connector body -------------#4 Tan------------ - by it's self #1 Dark green and #5 Red - are side by side #3 Dark blue and #2 White - are side by side #Ground (Black) This one is off to the side of the switch body If that is not what the wiring colors look like at the back of the ignition switch tell us what it is like. Look at the battery (+) lug - What goes that cable go to? Look at the battery (-) lug - What goes that cable go to? What are you using for testing? Digital multimeter? Analog multimeter? - with a dial and needle Test light? Garry Share this post Link to post Share on other sites
Hendricksn 7 #34 Posted February 10, 2015 Here's the order: Tan Dk green - White side by side Dj Blue - Red side by side I'm using a test light. And the (+) cable is on the solenoid. And the (-) is connected to the hood stand. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,533 #35 Posted February 11, 2015 Looks like the red and white are reversed. Let's double check it. You should have a 5-wire connector that holds the 5 wires. Pull that off the switch so you can read the letters on the back of the switch that identify each terminal. The red wire should go on the B terminal for battery The white wire should go on the A terminal for accessories Including a picture of the connector and the back of the switch. Have rotated the switch picture so the tan is at the top like we have written their description above. Wiring diagram #1 Dark green (Rectifier) R on switch Wiring diagram #2 White (Accessories) A on switch Wiring diagram #3 Dark blue (Magneto) M on switch Wiring diagram #4 Tan (Starter) S on switch Wiring diagram #5 Red (Battery) B on switch Let us know what you find. There is a way to release each terminal so they can be reinserted in the proper cavity - will explain that next time if necessary. Garry Share this post Link to post Share on other sites
Hendricksn 7 #36 Posted February 11, 2015 The new Napa switch isn't labeled. And I'm not sure how to attach my picture. But they're in the order of the diagram I drew so it's poss they're backwards. That could be why the previous owner had such a hard time with this thing The new Napa switch isn't labeled. And I'm not sure how to attach my picture. But they're in the order of the diagram I drew so it's poss they're backwards. That could be why the previous owner had such a hard time with this thing Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,533 #37 Posted February 11, 2015 Do you have that plastic connector on the wires or are they all individual? Garry Share this post Link to post Share on other sites
Hendricksn 7 #38 Posted February 11, 2015 It's still in the plastic connector Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,533 #39 Posted February 11, 2015 Disconnect the negative battery cable again and tuck it out of the way so it can't touch the post. Switch the red and white wires. Look at the front of the connector body where the switch terminals enter it. There is a groove in the plastic outside each metal terminal. You need to push something into that groove to collapse a tang on the metal terminal. The wire of a heavy duty paper clip or similar object works well. Push the tool in the front and pull the wire out the back. You may need to take a few stabs at it for the first one and the next will be easy. Take a knife blade and bend the tang back out a bit once the terminal is removed from the plastic body. The tang springs over a lump in the groove when reinserted and it's lock in again. Give it a tug to make sure. Hook the negative battery cable back up. My figures are crossed. Turn the key and start your engine. Garry Share this post Link to post Share on other sites
Hendricksn 7 #40 Posted February 11, 2015 I switched them and now the switch light is on and won't let it start. When all the other switches are in place and the seat switch did work. But now the lights on and if I push the button if makes no difference Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,533 #41 Posted February 12, 2015 There are about 5 lights there. Can you be more specific which one is on? Garry Share this post Link to post Share on other sites
Hendricksn 7 #42 Posted February 12, 2015 Seat switch Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,533 #43 Posted February 12, 2015 Disconnect the orange wire from the seat switch and wrap a rag around the wire so the terminal will not touch any metal part of the chassis. That may not put the light out but will stop the seat switch from killing the ignition. We will deal with that switch later. Make sure the pto lever is OFF, clutch pedal is down and try starting. Let us know what happens. Garry Share this post Link to post Share on other sites
Hendricksn 7 #44 Posted February 12, 2015 No dice. Still same result Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,533 #45 Posted February 12, 2015 The starter will not turn the motor over? Garry Share this post Link to post Share on other sites
Hendricksn 7 #46 Posted February 12, 2015 No. When I turn the key and try to start it the seat switch light comes on and nothing happens. But if I jump the solenoid with a screwdriver it starts. That's new. First time it's done that Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,533 #47 Posted February 12, 2015 Did it start and run on it's own? Or did it just turn over? Garry Share this post Link to post Share on other sites
Hendricksn 7 #48 Posted February 12, 2015 No. I had to jump the solenoid. The motor won't turn the key over The motor won't turn over by turning the key. You have to jump the solenoid Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,533 #49 Posted February 13, 2015 Let's leave the ignition for now and try to get the starter motor to engage. This drawing shows everything required to make that happen. Red wire feeds power the the ignition switch. Ignition switch in the START position feeds power to #1 - pto switch and #2 - oil level switch. . #1 - Pto switch is closed with the pto OFF. This sends power to the clutch pedal switch. Clutch pedal down the pedal switch closes and sends power to the switching relay's contacts. #2 - Oil level switch is closed if the oil level is OK. This feeds the magnetic coil in the switching relay which closes the relay contacts. (When this relay closes you should hear or feel it closing - a click or thump) When #1 and #2 are both satisfied the switching relay sends power to the small terminal on the starter solenoid. Starter solenoid closes and starter motor should turn. You may need help to do this unless you have an extra pair of arms and hands. It will be easier to start at the starter solenoid and work you way back to the ignition switch to see how far the power is getting. Pto must be off - thats easy Push clutch pedal down Turn key to start Check for power in the purple wire at the starter solenoid small terminal. None there- Remove the switching relay and wires so you can probe the terminals with them still connected to the relay. The light blue wire and dark blue wire should both have power in START. If they do have power the purple wire should have power provided the relay clicked. The relay coil requires a ground to work so it may have a black ground wire - make sure it is connected to the chassis to complete the circuit. The pointed arrow in the diagram is a ground. Remember to turn the key to START for each test. Let us know what you find to this point. The reason for checking it from the starter back towards the ignition switch is the clutch pedal switch is hard to get to as it is down below the panel your shifters come out of. It is activated by the idler pulley arm that tensions the belt. With a light you can look down below the shifter and see the switch. This switch seldom fails. If you click on the illustration it will get larger. Garry Share this post Link to post Share on other sites
Hendricksn 7 #50 Posted February 13, 2015 The orange wire at the solenoid has power with the key in the start position. I didn't check any of the others because there was power to the solenoid. So I need a new one? Share this post Link to post Share on other sites
