gwest_ca-(File Mod) 10,499 #1 Posted December 20, 2014 The information available lists the engine as K241S-47176. This is not correct as 47176 is a K301 12hp spec number. Anyone have an original engine that they can post the correct spec number from? It may be K241S-46215a Garry Share this post Link to post Share on other sites
oldlineman 1,450 #2 Posted December 21, 2014 Not sure if this is what you want Garry but I have a K241AS with spec.# 46766d. Not sure what the A means. Hope this helps . Came on a 1979 c 101 original engine. Bought new by me. Bob Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,499 #3 Posted December 21, 2014 I am after the engine numbers for the 1965 tractor model number 1054A. Garry Share this post Link to post Share on other sites
oldlineman 1,450 #4 Posted December 21, 2014 Sorry Garry I just saw K241 and new I had one. Share this post Link to post Share on other sites
Martin 2,130 #5 Posted December 21, 2014 Garry, the 1964 1054 of mine has a K241S-46215a spec number. I cant see why they would have changed it from that for the 1965 models. As you probably know they did use the same like hp engine spec numbers on multiple tractors in 66 and 67 (and probably other years as well)...... I guess until somebody chimes in with definite info to be sure..... Share this post Link to post Share on other sites
pacer 3,159 #6 Posted December 21, 2014 A well documented 1965 1054A with a Kohler 241-S spec 46215D, - s/n A-120306. The obvious difference being the D on the end instead of A.... ?? Share this post Link to post Share on other sites
