wheel horse rear hitch stuck
By
redsquarebob, in Transmissions and transaxles
Similar Content
By bob54
How do I get this pin out, I've tried heat, rust penetrate, and an air hammer, and just rust penetrate and the air hammer. I can't get it to move, no matter what I do,,and yes I removed the clips from both ends. I knew you were thinking about that
By rwilson
This might be a dumb question but i'm sure some of you have dealt with this. How do you get the pin out of the rear when it is rusted in there? I just bought a clevis hitch today but i cant get the pin out to put it on.
By scotty
My hitch pin is stuck in my b-80. I was wondering if i were to use my torches where would be the best place to heat it. I was reading someone said not to heat the pin. But if you heated the case wouldnt it end up hurting the transmission split gasket?
