Countdown To Christmas!
cheesegrader
'97 48" deck spindle assembly
cheesegrader
I have a new to me 48" deck.
I struggled getting the old blades off to sharpen and balance, using using chemicals, torches, BF Hammers and magic words!
In the process, I loosened the nuts at the top and bottom of one of the spindles.
I tighthend them back down, but they spin loose almost immediately when I try to mow.
How tight do these nuts need to be?  Can they be too tight?
I can always apply more torque, or add thread locker, but I don't want to ruin a spindle or bearing.
P.S The mower worked just fine before I started messing with it!!!!!
Forest Road
I think there are stops on the spindles. Meaning the nuts will only go so far. I would advise using lock tight to retain the spindle and pulleys. Don't use lock tight on the nuts holding the blades. The nylock nut should be sufficient for the blades. I usually use an open end wrench and hit it with a 4 lb hammer to break blades loose. I use the same hammer to tighten them. One or two good shots is plenty.
If I were at my home garage I'd be using a 1/2" air impact gun. Don't have that luxury up country.
A word of caution I always wear a decent pair of leather gloves when changing blades. Your knuckles will appreciate it.
