Parke1 0 #1 Posted September 8, 2008 Hi gang, This is my first post here. I have two Horses, a 1973 8-Horse 4-Speed, and a 1985 314-A. I love both of them. The 314 is my primary riding mower, and the 8h-4s just gets joy ridden from time to time. Anyway, I found a Wheel Horse snow plow, but I don't know what it is, or if it will fit either of my tractors. Here are the two best pictures I could get: Any ideas what this came off of, or what it will fit? Hopefully one of mine... Thanks guys! -Parke1 Share this post Link to post Share on other sites
CasualObserver 3,406 #2 Posted September 8, 2008 First... lots of good people here with good information. Can you post the numbers off the tag in the circle? The model number is on that tag. I'm not familiar with that frame, could belong to a vertical shaft tractor? Joel... does that belong to one of your style of herd??? Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,345 #3 Posted September 8, 2008 :banghead: I'm with Jason, I'm not familiar with that frame either. It don't look like any Wheel Horse snow plow frame I have seen, but again, I'm not as fluent in Wheel Horse as some here are. But, here is a good thread that has a lot of great info on some of the snow plows available: Snow Plow Info Share this post Link to post Share on other sites
pond195520032003 27 #4 Posted September 8, 2008 I would also like to say im pretty sure that is for a vertical shaft model but Joel will know for sure for a minute, nice I.H. #2 trailer you got there ok, back to topic :lol: Share this post Link to post Share on other sites
Teddy da Bear 11 #5 Posted September 8, 2008 :banghead: So glad you could join us! I am unfamiliar with that style of frame too. I would guess it is for a specific tractor style.......definately 70's Even if it is a vertical shaft design....I still think it will work on your 1973 tractor. Share this post Link to post Share on other sites
Parke1 0 #6 Posted September 8, 2008 Thanks for the warm welcome! I can buy that snowplow for $100. According to the owner, it belonged to his father and was never mounted on a tractor, but he can't remember what kind of WH he had... The guy isn't the most friendly, so I'm not sure if I can get him to send me the model ID off of the tag. If I can find that, can it be cross referenced to see if it'll fit my 1973? It has the quik-tach system, but I can't tell if the plow has that same style set-up, since I don't know that much about them yet. Thanks again! -Parke1 :banghead: Share this post Link to post Share on other sites
Teddy da Bear 11 #7 Posted September 8, 2008 Oh if it isn't already yours... I would "personally" pass on it. Get the style of blade that was made more for your style of tractors. I believe if you do a search of the impliments gallery....you could find an example of a 70's style of snow plow. And...if your so inclined... Come to the Mentone Indiana tractor show and swap meet on the 20th-21st. of September. Mentone is featuring wheel horses! See the posting under general shows. You might find something to better suit your needs. And then there is the bigger swap meet (all tractors) in Portrland Indiana in October. Share this post Link to post Share on other sites
Kelly 1,028 #8 Posted September 8, 2008 :banghead: That is for sure a vert. plow, for I belive the A and B series Share this post Link to post Share on other sites
combatmp29r 27 #9 Posted September 8, 2008 No model number needed. Its a vertical shaft snow plow for the A series (A80,A90,A100) 6-7122 or 23. Its the same as the 70-73 6-7121 plow, except they slotted the mounts instead of just having through holes. Easy of install was the reason I've been given. Will it fit any of your horses? NO!! Not with out alot of modification. These mid mount just behind the front wheels, but not in the same spot as a mid mount attach-a-matic. So you would have to cut off the ears and extend the frame, and also fab a new lift point. The verts lift the plow by pushing down and forward using the mid mount as a fulcrum, instead of lifting like the horizontals. My advice, would be to save the $100 and put it towards the proper blade. They pop up for that or less quite often. Just my $.02 1 Share this post Link to post Share on other sites
Parke1 0 #10 Posted September 10, 2008 Ok, I looked around for a couple days, and wound up purchasing a blade exactly like this one: Now, the model number off of mine is 42BC01-1792 Which of my two Horses will this fit? Either the 1973 8-Horse 4-Speed, or the 1985 314-A? The 73 already has a rear mount bracket on the axle, and the blade came with one which I can add to the 314. Thanks for the help! -Parke1 Share this post Link to post Share on other sites
pond195520032003 27 #11 Posted September 10, 2008 this blade will fit both tractors will also fit the short frame tractors as it has the extra holes in front of the rear ones might have to get a different rear attach a matic but i would try it first to be sure also might have to turn the angle arm around(might hit the running/foot boards on one or both tractors) great find though :horseplay: :banana: Share this post Link to post Share on other sites
WheelHorse_of_course 99 #12 Posted September 12, 2008 I have one like this. Fits the 854 as is. For the Charger the running board is in the way. Before I got the 854 I just used this without the angling arm. I would just get off to change the angle. This winter the charger will have the blower and the 854 the plow, so I'll be ready for anything :horseplay: Share this post Link to post Share on other sites
Craig Arndt 6 #13 Posted October 16, 2008 You've done well grasshoppa. That is the right blade and a lot tougher. My 48" blade weighs a ton, so even without down pressure, its got a lot of its own. Wish you well, happy blading! :USA: Share this post Link to post Share on other sites
