Brian1045
Brian1045's 1045 restoration
Brian1045
Here are a few pics before I start tearing her down. Thanks in advance for all the help I will be bugging you all about :banghead::USA::omg:
peace...Brian
ol550
:lol: Green tractor :lol: Maybe it will ripen with age. :omg:
:banghead: Green hat? at least it's not on backwards. :USA: :thumbs:
bell
FINALLY! Some good reference pictures for how my 1045 is supposed to look... :USA::banghead: :omg:
Brian1045
Bell,
I have ALOT more pics that I took. So if let me know if you want them...I can email you them all.
Well...actually I did have the green hat on backwards to take some of the pics...it kept getting in the way of the flash.
Brian1045
I was amazed how well these Rims turned out from the Sand Blaster I borrowed from a buddy of mine.
I also ran a wire brush wheel over them...just to take off the dust coating from the sand. Aluminum oxide seems to be the choice sand/grain. It is expensive, but we can use it over and over again.
bambooheels
nice job, looks really good, i have a pair myself to do today, wish me luck. hopefully will turn out as nice as yours
Stigian
Wow, sandblasting makes a really good job of cleaning those rims :USA:
You just need to polish them and seal the shine in with a few coats of clear :banghead: :omg:
64s
Brian,
What kind of sand blaster did you use? It looks like it did a fantastic
job!!!!!!!
:banghead:
Brian1045
Actually the blaster was a home-made jobby.
A ceramic tipped sand blasting gun attached to a air compressor, thats about it. The Aluminum oxide sand was the trick. It won't break down like silica sand. It's well worth it. Be careful....Sand blasting gets addictive. What can I do next? :horseplay:
Thanks for the comments.
Link to sand used below
http://www.mcgillswarehouse.com/ItemsList....N=ALUMINUMOXIDE
BairleaFarm
How long did it take you to do those 2 wheels?
Brian1045
Here it is stripped down. :USA: I left the front rims on for now, so I can still wheel her around. I'll keep posting from here on the progress through out the restoration. :banghead:
refracman
:horseplay: Let the fun begin! :horseplay:
Good Luck. Doing restos can be fun and frustrating but the end results are worth the headaches
BairleaFarm
Looks so sad sitting there all stripped down. Have fun and take lots of pics
Kelly
Do your self a favor and put diff. front tires on it to move it around, one slip, with a tool or run into something sharp and good luck finding another tire like that :banghead: and yours look to be in very good shape.
Brian1045
Yea..It's been pretty fun so far. The rear wheels are primed and ready for White. I'm putting the frame on a special set of saw horses, and the front wheels are coming off in a couple days. Tires are coming off (carefully) and going on the shelf for now.
This forum has been awesome. It makes the job a lot easier knowing you have good people backing you up. It's like you guys are here in the garage!
thanks! :banghead:
More to come later :horseplay:
kpinnc
:banghead:
The FUN begins!
Keep the pics coming!
Kevin
BairleaFarm
Hey I have that same wheelbarrow and it looks just like that.
Brian1045
About an hour or so...maybe a little longer... I wasn't as picky on the back side as I was on the front.
Brian1045
All The parts and the tranny plate add-on
Brian1045
More Pics ...I'm still working :horseplay:
Brian1045
Dry and Clear coated
bell
Looking GOOD! :banghead:
Brian1045
And Yes...I realize I need to swap the wheels and put the Valve stems on the inside. :banghead: :imstupid:
Kelly
Might want to ask around about the valve stems, mine are I think on the outside, I have 2 1045's I'll check tonight after work, maybe someone else will chime in.
Brian1045
Well You'd think the grease fitting would be on the inside to....but right now it's on the ouside along with the valve stem. I Say personal Pref. :banghead:
