steve k 82 #1 Posted March 29, 2013 Hello everyone. The snow is finally melting and soon I will have yard work to do! Between the chickens and my snow plowing there is quite a bit of raking needing to be done in the yard this spring. I cant afford to buy a small york rake so I was wondering if anyone has tried fastening teeth of some sort to a board or piece of steel and then just clamping or bolting this to a snow plow so the teeth hang down below the cutting edge of the plow and rake the yard this way?!? I could lean the blade forward which would tilt the teeth back to change the aggressiveness of them. I was thinking 3/4" wide band iron or hay rake tines for teeth. Am I crazy??? Share this post Link to post Share on other sites
Whmaverick 54 #2 Posted March 29, 2013 I don't think your crazy. How do they say? Necessity is the mother of all inventions. If it works for your purpose then it s a great idea. Just remember, we desire pictures. Share this post Link to post Share on other sites
coolhandblack 45 #3 Posted March 29, 2013 how about just making something like this? Wouldnt take much if you have a welder. Sorry fellas... Share this post Link to post Share on other sites
KC9KAS 4,741 #4 Posted March 29, 2013 how about just making something like this? Wouldnt take much if you have a welder. I don't see anything....Had the same problem last night....maybe my 'puter is messed up? Share this post Link to post Share on other sites
SousaKerry 500 #5 Posted March 29, 2013 Your not alone I don't see anything either Share this post Link to post Share on other sites
steve k 82 #6 Posted March 29, 2013 There is no pictures. I thought the plow/rake would work better than a tow behind because it would be easier to pile up the debris instead of continually dragging it around. Push into a pile, raise the blade and back up to get some more. Its tough to back up with a drag behind rake. I am going to TSC today I will post pictures as I progress. Steve Share this post Link to post Share on other sites
can whlvr 991 #7 Posted March 30, 2013 i have a set of ripper blades that i made for my mid mount grader blade,a guy could make a similar set up that used smaller teeth,heres a pic,its removable and i have put it on my snow blade to chop ice in front of my garage door where the mid mount coulnt reach Share this post Link to post Share on other sites
kaiser 100 #8 Posted March 30, 2013 check out JUSS10's drawing of a cool rake here: scroll down to his drawing. Share this post Link to post Share on other sites
