radarme
Dipstick for Tecumseh H series motor
radarme
I have an H55D I'm working on restoring.... One of the things it did while running is the dipstick kept popping out. It seems like the threads on the dipstick just can't grap the tube well enough. Maybe the gasket is too thick? The gasket is about 1/8" thick. If I take it off, it threads on down really tight. Any ideas?
thanks
MarkPalmer
Make sure the engine's breather is working right and not allowing the crankcase to be under pressure which can pop the dipstick out. If that is OK and the threads are just worn, thinner gasket or new diptick would be in order.
-Mark-
COMMANDO6
My H60 uses a washer-gasket thing that is as thick as cardstock.
radarme
The breather will get a nice cleanup and I think I'll just make a new gasket for the dipstick... Should fix it up. thanks
