pfrederi 20,014 #1 Posted May 8, 2012 The C141 I got at auction this weekend runs rough e.g. a lot of vibration. She has the isolation/shaker mount but even just at cranking speed she bounces a lot more than any of my 12hp 301s. I had the head off to clean it and check the valves and found she has been overhauled at some point (.010 over on the piston). I figure there are 2 possibilities here...One they left out the balance gears or two they didn't time them correctly. ( I did my M12 and it was a picky job putting the timing gears back in, but she is a lot smoother than this 321.) I know a lot of people say get rid of the balance gears. My question is does that make the engine vibrate noticeably more??? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted May 8, 2012 My question is does that make the engine vibrate noticeably more??? In short, the answer is no. Since you know it's been worked on in the past, it is possible that someone could have installed a K301 crankshaft, which is dimensionally identical, but balanced differently than the K321/341 crankshaft. Share this post Link to post Share on other sites
bowtiebutler956 650 #3 Posted May 8, 2012 I left the balance gears out of my K301 when I rebiult it, and it doesn't vibrate any more than it did before. Matt Share this post Link to post Share on other sites
Duff 206 #4 Posted May 8, 2012 Over the years I've read a lot of threads about this very subject here and the consensus has been almost unanimously that the balance gears are next to useless and, worst case, prone to grenade a block. I can't recall a whole lot of "positives" for keeping them in. A few people have suggested that Kohler must have put them in for a reason but I don't recall anyone saying why they did. JMHO...... Duff :thumbs: Share this post Link to post Share on other sites
Guest skinner #5 Posted May 9, 2012 To me it seems one of the reasons they are even there in the first place is just to provide lateral counter balance in response to the crank. Are they also designed to 'help' the crank out in ballancing the piston and rod as well? Share this post Link to post Share on other sites
pfrederi 20,014 #6 Posted May 9, 2012 Well I guess its time to pull the engine and take off the oil pan for a look. I am hoping they screwed up the balance gear timing...Having to get a new crankshaft is not a pleasant thought. This project just got switched to a slower track. This is a big week for my one of my other hobbies...The East Coast Military vehicle show at Aberdeen MD :) Share this post Link to post Share on other sites
Buckshot 1 15 #7 Posted May 10, 2012 When I rebuilt my K321, I throwed the balance gears in the scrap pile. This engine is not in a WH, it is solid mount, no ISO mounts and I do not notice any difference in the vibration. When I rebuilt my K301, no balance gears and its also a solid monut. I had too many old timers tell me about the gernadeing balance gears. I kind of womder if Kohler got smart and realized the problem with those gears, which is why some engines have them and some not. Don B. Share this post Link to post Share on other sites
Don1977 605 #8 Posted May 11, 2012 Kolher built engines with and without them, that should tell you that they are not needed. Share this post Link to post Share on other sites
pharmer 0 #9 Posted May 16, 2012 I've read you may notice some vibration at low rpm but that's about it. I'm rebuilding my K321 right now, and the balance gears will be left out. Share this post Link to post Share on other sites
