WheelHorse_of_course 100 #1 Posted June 27, 2008 :WRS: Please move to technical FAQ section. From WH part #810134R1 B, C, D manual The following applies to C-series tractors. I suspect the it also applies to later tractors. PTO Clutch If slippage is encountered turn the trunnion towards the rear of the rod in one-turn intervals until clutch slippage is eliminated PTO Brake 1) Engage the PTO 2) Loosen the two bolts that hold the brake pad to the support bracket. 3) Place a 0.012" (.3 mm) feeler guage between the brake page and the clutch pulley 4) While holding the clutch pulley firmly against the feeler guage and pulley, tighten the two brake bracket bolts. There you have it :whistle: Share this post Link to post Share on other sites
