C-195 0 #1 Posted June 23, 2008 Does anyone know where one can find the v-belt for the rear power takeoff for the Wheelhorse C-195? It is WH# 109829. It's a 4L belt with a length of 153.25". Share this post Link to post Share on other sites
CasualObserver 3,406 #2 Posted June 23, 2008 First Welcome, jump in and post often.....This very topic actually was just brought up not too long ago.... Please reference this thread... it has your answers. http://www.wheelhorseforum.com/index.php?showtopic=2816 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,345 #3 Posted June 23, 2008 :whistle: I was going to respond that I've exhausted all the links in the "Links" section here to no prevail. But it looks like the link to the thread Jason posted might be the answer you're looking for. Good luck. Again, welcome to the site. Share this post Link to post Share on other sites
DMESS 24 #4 Posted June 23, 2008 C-195, did I happen to talk to you about these belts at the WHCC show this past Weekend? Is your name Jim by chance? Share this post Link to post Share on other sites
C-195 0 #5 Posted June 24, 2008 Yes we did. So far, no luck. Share this post Link to post Share on other sites
Teddy da Bear 11 #6 Posted June 24, 2008 I do not know anything about your particular situation. But what I have done in the past is adapt the next size belt to do the job. Most wheel horse applications have an "ideal" size belt. But the engineers at wheel horse must have been doing their homework, because in many situations, belts of larger or smaller sizes can work. In one particular instance: My sickle bar mower. The belt is suppose to be 141 inches. Now no one makes a 141" belt. It is just not a common size. Wheel horse might have made the belt, but most came in 2 inch increments after 100 inches. So I was able to use the 140 inch belt that Napa had. Yes it goes on a little tighter, but it still works. And if I wanted the "fit" that wheel horse intended I could always change the diameter of one or both of the idle pulleys. I could likely run a 142 inch or a 138 inch belt too. So I was wondering if you could change something up to better use a more common size belt? Share this post Link to post Share on other sites
C-195 0 #7 Posted June 24, 2008 I just found one at 158 in. I am going to try that. Thanks Share this post Link to post Share on other sites
Teddy da Bear 11 #8 Posted June 24, 2008 But you said it was suppose to be 153 1/4. Now your able to jump 5 inches and use one that is 158???? Share this post Link to post Share on other sites
DMESS 24 #9 Posted June 24, 2008 Jim, I'm glad you decided to check us out and join in the "madness"! Seriously, this site is a great source of information and I think you will find it to be superior to other WH sites you may have been disapointed with in the past. Share this post Link to post Share on other sites
Teddy da Bear 11 #10 Posted June 25, 2008 Let us know how it works out for ya. Share this post Link to post Share on other sites
