KC9KAS 4,741 #1 Posted August 20, 2011 I am needing a wiring diagram for a 1969 Work Horse 700 with a TECHY H-70 engine. It has the diode set-up. I do not know where the diode wires connect, as the ignition switch was broken with terminals missing. I would also appreciate any trouble shooting information.....right now it does not have any spark. I'm not sure if it is a wiring problem or a breaker points problem. Thanks in advance for your knowledgable assistance. If you have printed material, you may PM me with this info. Share this post Link to post Share on other sites
JimD 3,345 #2 Posted August 21, 2011 There are two manuals for this year... http://www.mywheelhorse.com/graphics/file/...41_A-5241-1.pdf http://www.mywheelhorse.com/graphics/file/...41_A-5241-1.pdf The difference is in the spec number of the engine. Without looking into it i would guess it has something to do with the diode or something about the ignition. Others will know more I'm sure. Share this post Link to post Share on other sites
KC9KAS 4,741 #3 Posted August 23, 2011 JimD, I think both of these links are the same.... Is that what you wanted to send? Share this post Link to post Share on other sites
JimD 3,345 #4 Posted August 24, 2011 Well no, not what I intended, but there seems to be an error on Mikes site. (Mikes RJ) Look here... http://www.mywheelhorse.com/modules.php?na...=show_doc&id=14 and you will see two listings for the manuals. But it appears you are right, they are the same. The second one on the site lists a different engine spec. I will make Mike aware of it. Share this post Link to post Share on other sites
KC9KAS 4,741 #5 Posted October 18, 2011 Well, I got this tractor started. The points would not open, so I adjusted them and it started & ran pretty good...I even mowed a little with it. I still need an ignition switch for a magneto ignition, and the TORO dealer said it is NLA. Anyone have suggestions? Share this post Link to post Share on other sites
