418a 0 #1 Posted November 4, 2009 I picked up a charger 10. How can I tell if the trans is good if it doesn't have a motor in it?Doesn't have fluid around any of the seals,it looks tight!Any help would be great!! Thanks Brian Share this post Link to post Share on other sites
pfrederi 21,095 #2 Posted November 4, 2009 No for sure way to test it as you can't heat it up. May be dry around the seals because there is no fluid in it With the valve set to drive try to jam the input pulley (a wedge, a clamp or a belt wrapped around it) so it won't turn then try pushing the tractor...should be stiff resistance... Share this post Link to post Share on other sites
418a 0 #3 Posted November 5, 2009 Paul,Thanks for that info!!I moved the valve to move the tractor and put it back there is a resistance there so you think it will be alright???? I'm thinking about repowering it with a 4 HP,something to play with until I find a 10 for a GOOD price.Need a hood for it though.Something to pull a trailer around.Brian Share this post Link to post Share on other sites
can whlvr 994 #4 Posted November 6, 2009 its vertually impossible to tell utill u put a motor in it and run it for a while,the 4 hp wont be enough to get full pressure,i have a c120 with a 6.5 in it and it will drive around but it is not near enough. Share this post Link to post Share on other sites
418a 0 #5 Posted November 6, 2009 Do yo think it will move at all? Waste of time. Brian Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #6 Posted November 6, 2009 If the 875/876/877 models could use an 8hp engine to power the hydro and a 36" (or even 42") mower deck simultaneously, there's no reason why a 4hp engine can't provide enough power to run the hydro unit enough to "putt around". Share this post Link to post Share on other sites
418a 0 #7 Posted November 11, 2009 Terry,I'm Puttin around can't get my girls off it Pulled a trailer and all Brian Share this post Link to post Share on other sites
