Transmission Gear Uni-drive 6 forward speeds 1.000in 4-pinion 6J 110996 1985-1993 IPL.pdf
1986 Model 110996
4 pages 2MB
1991 Model 110996
4 pages 189.82KB
1" axles
4 one-piece pinion differential
The 310-8 in this parts list uses the 110996 with 1" axles except for the few listed at the bottom of the page.
Used 1985-1993
1985 310-8 model 21-10K801
1985 312-8 model 21-12K801
1985 314-8 model 21-14K801 - Guessing this one is correct
1986 308-8 model 21-08K801
1986 308-8 model 21-08K802
1986 310-8 model 21-10K802
1986 310-8 model 21-10K803
1986 312-8 model 21-12K802
1986 312-8 model 21-12K803
1986 512-D model B1-12R801
1986 512-D model C1-12R801
1987 308-8 model 21-08K803
1987 310-8 model 21-10K804
1987 312-8 model 21-12K804
1988 308-8 model 21-08K804
1988 310-8 model 21-10K805
1988 312-8 model 21-12K805
1988 312-8e model E1-12K801
1988 316-8e model B1-16O801
1989 310-8 model 21-10K806
1989 312-8 model 21-12K806
1989 312-8e model E1-12K802
1989 316-8e model B1-16O802
1990 310-8 model 31-10K801
1990 310-8 model 31-10K801 serial numbers 11752, 11753, 11754 and 11755 use 1-1/8" axles and 4 pinion gears
1990 312-8 model 31-12K801 listed at Toro. Wrong and should be 110995 with 1-1/8" axles and 8 pinions
1990 312-8e model R1-12K801
1991 310-8 model 31-10K802 Serial 1900001-1999999
1992 310-8 model 31-10K803 Serial 2900001-2999999
1993 310-8 model 73320 Serial 3900001-3999999
