Transmission Gear Uni-drive 3-speed 1.000in axle 4-pinion 5053 1966-1969 IPL.pdf
Model 5053
2 pages 973.29KB
1" axles 2 of 3904 10-5/8" long
4 two-piece pinion differential three-speed
3-speeds have the brake drum mounted on the 11/44 (mushroom) gear. Use Section II of the service manual.
Model 5053 replaced 5007, 5025, 5046 and 5049
Suspect the model 5043 at the Toro Master Parts Viewer is a typo and should read 5053
Model 5053 transmission used in
1966 model 606
1966 model 656
1966 model 706
1966 model 856
1966 model 1046
1966 model 1056
1966 model L-106 Lawn Ranger
1966 model L-156 Lawn Ranger
1967 model 657
1967 model 857
1967 model L-107 Lawn Ranger
1967 model L-157 Lawn Ranger
1968 Lawn Ranger model 1-1631
1968 Lawn Ranger model 1-2631
1968 500 Special model 1-3631
1968 Commando 6 model 1-4631
1968 Commando 7 model 1-3731 - Made in USA and exported to Europe - No info available so this application is a guess
1968 Commando 8 model 1-4831
1969 WorkHorse 700 model 1-3741
1969 WorkHorse 700 model 1-3745
