Countdown To Christmas!
Blade Dozer 42in 1966-1967 BD-426 Long frame OM IPL DNA SN.pdf
Operator manual #281
4 pages 713.45KB
Toro states the BD-546 was formerly the BD-426 but not true. The BD-546 fit the 953, 1054 and 1054A. They did share a parts list.
Fits long frame tractors 10hp and up
Complete blade
Mounts ahead of rear axle
Replaced by 6-1111
Dozer 1966 42in model BD-426
1966 serial numbers that have shown up for the BD-426
189054
293111
Dozer 1967 42in model BD-426
Dozer DNA of long tractor frame dozer blades
1966-1967 model BD-426 - Fits LONG frame tractors - Mounts ahead of the rear axle - replaced by
1968 model 6-1111 - Fits LONG frame tractors - Mounts ahead of the rear axle
1968 model 6-4111 - First to fit LONG & SHORT frame tractors and first to mount under the rear axle - Lift bracket behind crossmember 7716 A-frame - replaced by
1969 model [6-4112 + 6-9621] - First to have the lift bracket ahead of the crossmember 7716 A-frame
1970-73 model [6-4113 + 6-9622]
1973-74 model [6-4113 + 6-9623]
1974 model [6-4114 + 6-9624]
1974 model 6-2131
1975 model 6-2132
1976 model 6-2133
1976 model 66-42BC01
1977 model 76-42BC01
1978 model 86-42BC01
1979 model 96-42BC01
(1968 model 6-4111 to 1980 model 06-42BC01 use the same 7716 A-frame assembly but the lift tab changed according to the ipl's)
1981-1984 model 06-42BC02 (Up to here they are 42" wide) (Uses 104341 and 3771 index wires - See file for dimensions)
1984-1989 model 06-48BC01 (They are now 48" wide) (Uses 104341 and 3771 index wires - See file for dimensions) [M]
1990 model 06-48BC02 (Last blade to have 3 angle positions)
1991-1993 model 06-48BC03 (First blade to have 5 angle positions)
1993-2001 model 79350 - (105-1502 kit adapts 2001 and older GT Classic-Series blades to fit 2002 and later tractors
2002 2004-2009 2012 model 79364 - (105-1501 kit adapts 79364 blade to fit 2001 and older GT Classic-Series)
