OHLB
Won't start
OHLB
Newbie here. 310-8 won't start. Battery is dated 10/19. Did crank a couple times but started losing ummph. Should I replace it or attempt to charge it? Can't tell if the battery is frozen. Never knew until today that batteries could freeze and that it's dangerous to charge a frozen battery. It's been single digits with wind chill the last couple weeks here.
squonk
Your battery is over 2 yrs. old and dead. The batteries may last 3 on average. Replace it.
  • Like 4
pfrederi
Many 310-8 had a 3 amp unregulated charging system.  That isn't going to bring back a sick battery I think interstate battery put a time release suicide pill in the L&G batteries...
Edited by pfrederi
SylvanLakeWH
Bring it inside, let it warm up and see if it will take a charge room temperature warm. If not, as noted above, time for a new one…
:twocents-twocents:
Tuneup
Yeah, that!
... and don't forget that with a 50 MPH wind on a 20° day it's still 20°. If the wind wasn't blowing and the sun was shining, you'd be relatively warm at 20° without wind thanks to your skin's boundary layer. With wind, you'll feel the 20°. Still, that reality isn't scary enough so "it really feels like -10° and you're gonna die!"  Bull!
Every weather man/woman should pay a fee when they're wrong but they'd all be broke by the end of the week. /rant
OK, I doubt you'll have freeze issues on that battery above 0° but charge the heck out of and see if it's any good.
pfrederi
Even if you can charge the battery up it may still fail you .  Load test is in order.  Poor man's load test, hook up you multi meter to the battery, voltage should be about 12.6 if fully charged then try cranking it.  If voltage drops down to 9 volts or less get a new one...
roadapples
:WRS:
Achto
:WRS:
TJ5208
:text-welcomeconfetti:
  • Similar Content
    • Big Rig
      By Big Rig
      ISO clutch neutral safety switch for 310-8
      or alternative
    • Rob R
      By Rob R
      Soo couple of years back did a pulley change on the tranny from 6 inch to 4.5 and used a 1/2 X 79 belt to make it work and it worked fairly well but wanted to get back to a 5/8 drive belt so went to a 5/8 x 81 inch belt and added a second flat Idler pulley. I simply cannot believe how smooth and sharp it shifts and drives now!  The added flat Idler was 2 3/4" with a 5/8ths bore used and existing hole on the side shroud and just opened it up a bit. I use to slip a bit on steep hill with the 79" slips no more, the belt drives and the clutch is  LOT smoother and in the right pedal area.... Will see how it holds up cut 3/4 of an acre of grass yesterday NO issues.
    • Ifixoldjunk
      By Ifixoldjunk
      So I was out mowing the other day with my 310-8 and somehow snagged my wheel in a hole in the yard. Anyways I pretty much destroyed my ball joints. I've since replaced the tie rod with junkyard parts but I was wondering if anyone's found a heavy duty aftermarket replacement for the tie rod assembly.
      Like would generic adjustable go-kart tie rods do the trick?
    • Ifixoldjunk
      By Ifixoldjunk
      so I spent a few hours today welding up a custom front weight bracket for my 310-8. It has two and a half inches of ground clearance with a generic 12 inch weight bolted on.
      so the question is, how well do y’all think the 300 series front axle will hold the weight? It’s only 50lbs so it’s lighter than the snowblower it has to hold up in winter so I don’t think I’ll have any problems. And I really don’t intend on using it constantly.
    • Ifixoldjunk
      By Ifixoldjunk
      I’ve recently gotten into flux core welding and I’ve been making all sorts of attachments for my 310-8. I was wondering what other crazy things people have made for their tractors.
