prink3
hydro swap
prink3
Anybody ever swap an eaton 700 out to an 1100. I did some searching and found that the transaxle is the same, differences being hydraulic plumbing to the transaxle and the spacer between the 700 and the transaxle.
Since the spool valve is open center, shouldn't it be ok to connect the pump discharge hose directly to the transmission filter inlet and operate without the hydraulic lift?
Thanks,
Mike
Horse Fanatic
I would think so. I intend to do the same thing with my 516H.
