Gregor
Craftsman engine.
Gregor
Mower for sale on FB. Says motor runs great. (of course) Who made these engines for Craftsman?584293306_craftsmanengine.jpg.5733c000d8f37455c2d8990db657bf60.jpg
Kind-a looks like my Briggs twin.
I thought the pic would be bigger. It says 4 cycle. Electronic Ignition. Twin Cylinder. Cast Iron Bores.
Edited by Gregor
bds1984
That is a Briggs and Stratton all day long.  Great engines.  If the engine is the 18 HP is has ball bearings on the crankshaft and can be used in our Wheel Horses.
Jeff-C175
I'm not certain about this but I don't believe they all have the THRUST bearing though.
A while back someone posted a briggs decoder ring for the engine model number and one of the numbers tells which crank bearing / bushing is installed.
Edited by Jeff-C175
bds1984
I've posed that number chart here many times.  Look for the model number.  Odds are in your favor it has ball bearings on the crank if it is 18+ HP.
kpinnc
Got one just like it. If it has a PTO bearing, it is a small one.
Jeff-C175
11 hours ago, bds1984 said:
Odds are i
That's the chart!  Thanks for posting again.  I need to print that out.
Odds are perhaps, but not ALL.
bds1984
As long as the second-to-last digit in the model number is a 2 or 3, the engine has a ball bearing crankshaft.  I always look for 422437 or 422447 on the 18s.
Edited by bds1984
