JeremyNzl
Kohler diy rebuilt K241 ticking
JeremyNzl
Hi Guys,
Looking for some advice,
We rebuilt this k241 with a +.010 piston, Its had a rebore to +.010 but they did it off the manual specs and not the piston.
Not ideal with an aftermarket piston but I wont get caught on this next time.
Its developed this oscillating ting noise, its not the metal cover its there with it on and off,
its 100% from the cam side, does it under low load / slow idle,
Have setoscoped the motor with a screwdriver to the ear, and I cannot locate it.
but its in the top.
Have rechecked valvel clearances x2 already , 1st before initial run, and again day after, very minimal adjustment made after 1st run.
Ting noise clearly heard in the video , appreciate any advice.
Jeremy Nz
https://www.dropbox.com/s/txf8fciaqi5rozg/2021-06-10%2009.08.11.mp4?dl=0
Maxwell-8
but its in the top.
These are flatheads and the cam is level with the cam. Is the sound coming from the area cam-crank or from the vave area?
If it coms from the cranck-cam area. Did your properly torque the rod bolts?
Strange to hear is klicks now an then, not all the time  :eusa-think:
Maybe a broken bearing?
Edited by Maxwell-8
JeremyNzl
Yea its a cracker of a problem.
New crank bearing installed, with 1 gasket and 1 shim
Rod end was 2x torqued, 20%over then backed off and retorqued to spec.
I believe the noise to be around the exhaust valve. location.
I seem to get an unburnt fuel discharge with every ting,
When I short the mageneto out to stop it I get the same noise often till it quits rotating.
Edited by JeremyNzl
squonk
Exhaust Valve sticking. When it sticks and releases you will get a click like a tappet adjustment. Doesn't stick all the time so that will account for the oscillation. It would also account for the unburnt fuel. Were the guides and stems checked?
Edited by squonk
JeremyNzl
Thankyou for you diagnosis,
The rebuild kit came with valves, and i recut the seats to 46deg neway cutter and hand lapped them.
I do not have replacement guides.
I did not measure the stems nor touch the guides, I have the head off it atm so I will remove exhaust valve and reinspect.
I very much appreciate the advice received.
ri702bill
Jeremy:
Me thinks that Squonk has has accurately located your problem - and it IS a problem. If left as is, the exhaust valve will not always close and it will not be able to transfer its heat to the valve seat, resulting in a burnt valve.
Two items come to mind - chuck up the loose valve in a drill and spin it to check to see if it bent. Also, new valve stems are usually too long to allow grinding to fit to achieve your correct valve clearance to the tappet. Check your clearances for both valves.
My first instinct was a possible piston slap condition - most machine shops will NOT bore a block oversize without having the new piston on hand to verify its skirt size. Its not so much as the bore diameter but that the bore is round and provides the proper skirt clearance.
Bill
Edited by ri702bill
added piston info
  • Like 4
JoeM
Could the ACR not be right?
Just thinking.
Gregor
Possible loose valve seat?
tunahead72
Any updates @JeremyNzl ? :popcorn:
  • Similar Content
    • Rick3478
      By Rick3478
      For Sale NOS M12S Short Block, still in the original box.  I bought it pre-emptively when Kohler was phasing out the Magnums.  Thought I would have it on hand if one of mine needed it, or maybe I would find a tractor with a busted rod for cheap.  Neither of those things happened, the darn things just keep running.
      Part number 77 522 35, probably built in late '05, it's the combination replacement kit Kohler made to fit WheelHorse or Gravely, machined to bolt directly into the Gravely transaxle, but also has spacers to mount WheelHorse PTO clutch/brake.  Also has a bunch of gaskets and seals packed with it, probably all you need to install it.
      And it's heavy, so it's not practical for me to ship.  Buyer arrange to pick up near Elida OH, I can lift it about knee high to help load.
      Asking $800 or might consider trade for a good center mount grader blade.
    • mcfarmall
      By mcfarmall
      Tractor features Kohler 16hp cast iron engine, gently used 42" deck, concrete wheel weights, tire chains, new Chinesium carburetor, fuel lines and filter, new air filter, 2 new fwd/rev cams.  A starter,  some new gaskets, and miscellaneous parts.  New drive belt and all the belt idler assemblies.  Engine runs but smokes.  Great restoration candidate or a spare engine for you pullers out there.  Call, text or email for a private showing.   No offers considered unless made in person.  Buyer responsible for transportation.  Many more pictures to send to interested persons.
    • Jeff-C175
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
    • johnnymag3
      By johnnymag3
      416-8  clean machine, one owner, M16 Kohler...............no smoke, knocks, etc. Only 771 Hours.
      42" Rear Discharge deck   NO RUST    blades used 1 season
      48" plow very nice condition,
      Wheel Horse weights, on tractor already
      AG Tires on rear,used one season, front tires great condition. Rears are filled with beet juice, done at a Dealer professionally,  ....non toxic, non corrosive.  Traction Galore !!!
      Machine is fully serviced, ready to work. NEEDS nothing....Look below for pictures
      JOHN   845 797 5716 cell
