ryobi.warrior
314-8 Mower Deck Belt Contacting Bracket
ryobi.warrior
The belt on my Wheel Horse 314-8 mower deck (05-37SC01) appears to be contacting the deck bracket between the spindle pulleys. I am a novice when it comes to Wheel Horse maintenance (at best), but this does not seem correct.
I recently inherited this Wheel Horse, so I do not know the maintenance history. Unfortunately, the mechanic who previously worked on it was a no-show for a scheduled maintenance visit.
Any advice on how to address this? Thanks in advance... this seems like a great forum and I'm looking forward to spending time here!
Photos (please forgive the dirt and grime, I plan to clean it up!): https://imgur.com/a/4PknZuJ
Ed Kennell
:text-welcomeconfetti: to the :rs: ryobi.     I don't have that deck, but I would think the belt is not routed properly.     If you have the deck ID number, you can search for the manual on this site.
@gwest_ca      our file guru may be here soon to help you find the manual.
pfrederi
You belt routing looks correct.  The parts manual shows only 2 bolts in the bracket you are rubbing on you have 3  wonder if it is misaligned  I do not have one of these newer decks...
Edited by pfrederi
ryobi.warrior
Ed, thanks for the kind welcome and suggestions, and Paul, thanks for checking the routing. The manual diagram matches the sticker below, which is on the deck. I also noticed that third bolt (only two on the other bracket) and wondered if it might have not been properly aligned when reassembled.
I'm going to take another look. Thanks so much for the quick replies!
-R
Ed Kennell
I took another look at your photos.        It appears the "U" shaped bracket that is welded to the deck has broken loose allowing the deck to move to the rear causing the belt interference.
Look at the two rods at the front of the deck. They should be parrelel and it is obvious the deck has moved to the rear on the side in question. The wear mark on the front deck bracket also shows the deck has moved rearward.           The PO probably tried to correct the broken weld by bolting thru the deck  with the third bolt.
ol550
I'm thinking the deck is rusted and thin or possibly bent or cracked at the area between the bracket and spindle.  Clean up the area on the bottom to see,
Lee1977
The spindle may have moved back.
ryobi.warrior
Thanks, everyone. I truly appreciate the replies.
Ed, impressive call: the bolt does go all the way through the deck. The weld seems solid (to my untrained eye... rolling disclaimer for all comments). With the two original bolts off, the weld between the bracket mount and the deck does not seem to have any give, and it does not seem possible to move the bracket further back on the mount (fixed holes, not sliding). Does that look like an original weld?
ol550, I cleaned somewhat and I'm not seeing rust. Deck seems sturdy. Lee1977, I don't see any sign of movement or give on the spindle.
With all that said, does anyone have a suggestion for squeezing some more mileage out of this deck? All thoughts and suggestions welcome.
pfrederi
Welding was not always one of Wheel Horse strong points.  but that weld looks to have been redone at some point.  Compare it to the weld on the other bracket..  i wish i had a deck like that so i could takes some measurements for you.  If it were mine i would take a carpenters angle lay it against the good side hanger aligned with the cross shaft and see how far off the bad side is....
elcamino/wheelhorse
@pfrederi Look at the photo of the bottom of the deck. Looks like a patch to my untrained eye .
pfrederi
I agree.  Something was done to the deck.
Ed Kennell
Yes, the bracket appears to have broken loose and was rewelded with a patch underneath.   It looks solid now, but unfortunately it was not position correctly when it was rewelded.
You could cut it loose and reweld it in the correct position.     Or if the deck being slightly shifted to the rear on the right side doesn't bother you and it cuts OK.      Just grind the bracket to get clearance with the belt and keep on mowin.
Ed Kennell
     You could also replace the bushing in the right deck carriage bar with an eccentric bushing  with the hole positioned to the rear thus moving the right side of the  deck forward. The bushing gets pinched against the bracket  keeping the hole in the correct position.
dcrage
I don’t think the deck belt can be removed with the location of that bracket. The belts on 37” SD decks don’t have any tight spots when removing or installing!!
Edited by dcrage
ryobi.warrior
This was my next question! Given that I'm a novice with limited resources (I am not about to try my hand at welding), if grinding the bracket is a viable option, I'm inclined to give it a shot.
Unless anyone has a better idea, I will give it a try and report back. Thanks so much!
kpinnc
Agreed. I have had one of those decks. Your belts are routed correctly, but the bracket with the 3rd bolt is forward from where it should be quite a bit.
  • Similar Content
    • MSBiker
      By MSBiker
      Well it looks like I'm out of luck. I have been looking for blades for my Lawn Ranger and having zero luck. I have tried Wheel Horse part numbers 7908, 7909. Toro part numbers 8777, and 53322 and no one has anything like this. I was thinking about doing a cut down, but finding right hand and left hand blades seems to be the problem.
      Anyone making blades, constructing blades, got a work around, etc? My blades are usable, but that is about it.
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • Spottedeventer
      By Spottedeventer
      Hi! The shafts of my fathers old 314-8, deck number 73449 have worn to the point the blades don’t stay secured. I’ve struck out tonight trying to find a part number. If anyone can assist, I would greatly appreciate it.
      thank you,
      Patricia
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • Joe Warren
      By Joe Warren
      Mower Spindle Components
      mostly new old stock
      Prices shown do not include the cost to ship.
      Message me with your needs and any questions.
      Thank you.
      Joe
      PART NUMBER(S)
      DESCRIPTION
      QTY. AVAILABLE
      PRICE EACH
      103711
      NOS Spindle shaft assembly
      1
      39
      103711 (used)
      Used spindle shaft assembly
      1
      29
      101686 or 5875
      NOS Spindle shaft sub-assembly
      1
      49
      104890
      NOS Spindle shaft
      1
      49
      104982
      NOS Spindle shaft
      1
      44
      107998 or 107446
      NOS Spindle shaft
      2
      89
      109912
      NOS Spindle shaft
      1
      59
      112673 or 109965
      NOS Spindle shaft
      1
      59
      108849
      NOS Spindle shaft
      1
      89
      102780 or 104373
      NOS Spindle cups 1.0” tall
      2
      39
      NOS Spindle cups 0.9” tall
      2
      39
      102784 or 104374
      NOS Spindle cups 0.8” tall
      1
      39
      100289
      NOS Needle bearing, MFD USA Torrington
      2
      19
      101411
      NOS Ball bearing, sealed both sides, MFD China
      2
      29
      101480 or 1515 or 5493
      6
      9
      106084
      NOS Ball bearing, sealed one side, MFD Japan
      11
      9
      106085
      NOS Ball bearing, open, not sealed, MFD Taiwan
      16
      9
      106070
      NOS Seal spacer
      10
      9
      100674
      NOS Spacer-pulley
      1
      13
      107445
      NOS Spacer-bearing
      1
      9
      106069
      NOS Spacer
      1
      9
      110234
      NOS Lock bolt-pulley
      4
      2
      110242 or 908033
      NOS Lock bolt-blade
      11
      2
      915090 or 32146-20
      NOS Lock nut-pulley
      11
      2
      936028 or 32120-42 or 52-6640
      NOS Snap ring
      7
      2
      8389
      spindle housing
      1
      39
